L5740 weight?
/ L5740 weight? #1
PRF
Connecticut
2012 Kubota L5740, 1970 IH 2444, John Deere x485
Does anyone know the approximate weight of an L5740 with a cab, FEL, and loaded tires? I'm trying to figure out if the aluminum trailer I have for car racing is going to be enough to haul it if necessary. It's a Featherlite 18' with dual 3500 lb axles. Thanks in advance..
/ L5740 weight? #2
TractorData.com Kubota L5740 tractor dimensions information
Weight: 4,223 lbs [1915 kg] (cab)
Add in a FEL about 1,500 lbs or so
Plus about 700lbs per tire (SWAG)
/edit - plus fuel and chains and trailer
So your well over your weight even if the trailer weighed 0
/ L5740 weight?
Thanks fellas... Looks like its time to upgrade the trailer..
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
E-Z Trail 300-bushel Gravity Wagon (A66408)
E-Z Trail...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
Landhonor Quick Attach Rolling Packer (A66408)
Landhonor Quick...
Rustic Pine Bench (A66408)
Rustic Pine Bench...
