L5740 THIRD FUNCTION VALUE.
/ L5740 THIRD FUNCTION VALUE. #1
YARRA GLEN, Victoria 3775 AUSTRALIA
Thinking of buying a KUBOTA MX5100
Can anyone tell me what a third function value is or does and benefits if the option is available to have it? Im refering to a L5740.
Anyone have or used a L5740?
Is it as easy to operate as the brochure indicates?
And brochure specs say it has 59HP
/ L5740 THIRD FUNCTION VALUE. #3
3rd function is for auxiliary hydraulics on the FEL. Run grapples, 4 in 1's, etc.
No. But plenty have.
Every manufacturers brochure will say my tractor is easier to operate. I say they are all about equal.
The 59HP would be the power to the tires and the 50 is the power the PTO can put out to a mower or such. Many people measure only by PTO HP as that is really what determines what you can run with your tractor. You have to look at all the requirements are for 3PH attachments so you don't get something way to big or way to small for your tractor.
/ L5740 THIRD FUNCTION VALUE. #5
Sure does. Think of it like trying to run a rear mower without a PTO. You have to have those hydraulics up front to run the 4 in 1. Now, are those hydraulics in the base cost of a 4 in 1, I can't answer that, it may be more on top of that, but you would have to get it. (Or plumb one of the rear remotes to the front yourself, but that's not nearly as pretty)
/ L5740 THIRD FUNCTION VALUE. #6
Does that mean if I go for an L4400 HST model with 4 in 1 FEL i should automatically get it with the price i'd be paying for it>
I would not take for granted that the third function valve and associated plumbing to the front of the loader are included, especially if the bucket is provided by a different manufacturer. You need to make sure with the dealer that it is either included or added to your configuration.
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
IRET13 Electric Tricycle (A64047)
IRET13 Electric...
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
1137 (A63291)
1137 (A63291)
3PT HYD SCRAPE BLADE (A63291)
3PT HYD SCRAPE...
