L5740 hydraulic add on questions
   / L5740 hydraulic add on questions
A crossover relief valve is cheap & won't let line pressure spike to high. It's a more universal solution to as it will work just fine with a cylinder or a motor. It's also the simplest solution. The more complex & fancy things get, the more I appreciate simple system that just work with fewer failure points.
Thanks, that is a solution I did not know existed. That will most likely sway me away from another dedicated motor spool and control, thus saving me money and a more complex install. I appreciate it!
   / L5740 hydraulic add on questions #12
Any relief valve will heat up oil as it pushes open the valve. In the case of a PHD that will be insignificant amounts of heat. It might get toasty if it was a heavy rotary cutter or something with tons of momentum. Those typically have just a check valve so there is no resistance to flow when going into relief. No heat issues, but it means the circuit can't be run in reverse (not an issue for a mower, a deal breaker for a PHD & other stuff).
   / L5740 hydraulic add on questions #14
Yes. Most CUTS are 10gpm & 2,500psi so that would be appropriate. I'd set it to the top of its range a bit over 2,500psi. It comes at only 1,300psi by default.
Thanks for verifying.
2026 Anvil T/A Enclosed Trailer (A56859)
2026 Anvil T/A...
2022 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
John Deere 1025R (A53317)
John Deere 1025R...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2013 Ford F-250 (A55973)
2013 Ford F-250...
