L5740 hydraulic add on questions
   / L5740 hydraulic add on questions
A crossover relief valve is cheap & won't let line pressure spike to high. It's a more universal solution to as it will work just fine with a cylinder or a motor. It's also the simplest solution. The more complex & fancy things get, the more I appreciate simple system that just work with fewer failure points.
Thanks, that is a solution I did not know existed. That will most likely sway me away from another dedicated motor spool and control, thus saving me money and a more complex install. I appreciate it!
   / L5740 hydraulic add on questions #12
Any relief valve will heat up oil as it pushes open the valve. In the case of a PHD that will be insignificant amounts of heat. It might get toasty if it was a heavy rotary cutter or something with tons of momentum. Those typically have just a check valve so there is no resistance to flow when going into relief. No heat issues, but it means the circuit can't be run in reverse (not an issue for a mower, a deal breaker for a PHD & other stuff).
   / L5740 hydraulic add on questions #14
Yes. Most CUTS are 10gpm & 2,500psi so that would be appropriate. I'd set it to the top of its range a bit over 2,500psi. It comes at only 1,300psi by default.
Thanks for verifying.
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
2018 Cadillac Armbruster 70 IN Limo - Only 49K Miles - Luxury Transport, Clean, Well-Maintained (A56435)
2018 Cadillac...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
