L5740 hydraulic add on questions
   / L5740 hydraulic add on questions
A crossover relief valve is cheap & won't let line pressure spike to high. It's a more universal solution to as it will work just fine with a cylinder or a motor. It's also the simplest solution. The more complex & fancy things get, the more I appreciate simple system that just work with fewer failure points.
Thanks, that is a solution I did not know existed. That will most likely sway me away from another dedicated motor spool and control, thus saving me money and a more complex install. I appreciate it!
   / L5740 hydraulic add on questions #12
Any relief valve will heat up oil as it pushes open the valve. In the case of a PHD that will be insignificant amounts of heat. It might get toasty if it was a heavy rotary cutter or something with tons of momentum. Those typically have just a check valve so there is no resistance to flow when going into relief. No heat issues, but it means the circuit can't be run in reverse (not an issue for a mower, a deal breaker for a PHD & other stuff).
   / L5740 hydraulic add on questions #14
Yes. Most CUTS are 10gpm & 2,500psi so that would be appropriate. I'd set it to the top of its range a bit over 2,500psi. It comes at only 1,300psi by default.
Thanks for verifying.
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
large capacity skid steer bucket (A56857)
large capacity...
2015 Chevrolet Equinox SUV (A56859)
2015 Chevrolet...
2018 TowMaster T-12D T/A Flatbed Trailer (A55853)
2018 TowMaster...
Hydraulic Breaker (A55973)
Hydraulic Breaker...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
