L4701 3pt height adjustment
/ L4701 3pt height adjustment #1
cajunInExile
My L4701 has a stop with a twist knob on it to set the lower level of your 3pt hitch operation. With my bush hog and flail mower, I find that the knob loosens up with lifting and dropping at every turn, and I eventually have to move the stop back up, and then retighten the knob. Has anyone figured out a better solution? I was hoping for an aftermarket add-on that might make a better mechanical lower limit stop point.
If I could skip pass the lower limit without moving it, that would be cool to (backing up to a downward slope before resuming a level cut).
Thanks for reading!
/ L4701 3pt height adjustment #2
If you could somehow stick a washer or two on it, that might provide enough material to make the screw action much tighter (less likely yo loosen on its own)
/ L4701 3pt height adjustment #3
Someone here on TBN posted a mod on this very issue. I believe it was a quick release type lever that looked very secure and sturdy.
Parts and pics.
I have an OEM stop knob, but never use it.
/ L4701 3pt height adjustment #4
If you can remove the screw put a bit of Vibra-Tite VC-3 on it after cleaning and degreasing it. Unlike Loctite it allows adjustment after application. It acts kind of like a self locking nut.
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
Kubota MX6000 (A64126)
2011 Blue Bird School Bus (A62613)
2011 Blue Bird...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
