L4610 wont start
/ L4610 wont start #1
mtruhe
I went out to start my tractor today and it wouldn't start. When I turned on the key the lights on the dash came on for a second then shut off. When I turned the key I got nothing. When I turned the key off, I got a buzzing noise. Now when I turn the key on I don't get anything. The battery is fully charged.
I don't know if this is related but my glow light has been coming on intermitentlly while running also.
/ L4610 wont start #2
may sound obvious, but make sure the pto isn't engage. how old is the battery, starter bendix gear could be stuck etc. Tap on the starter with a hard mallet
regrads, Steve
/ L4610 wont start #4
Be sure the connections at the battery are soild as well as the ground and at the starter. A bad connection may sometimes let enough power through to operate the lights or even the glow plugs but once you load it with a few hundred amps off the starter, it fails.
/ L4610 wont start #5
Fully charged battery and good connections then I would look at the key switch as another place to look.
/ L4610 wont start #6
I'll add another that I experienced with my B7500.
My Rear/Mid PTO control lever was in the middle, neutral position, but the safety switch wasn't being pushed in far enough. I had to crawl under the tractor and fiddle with the linkage to get it working properly.
I think you are dealing with a safety switch of some kind. Just have to find which one.......
/ L4610 wont start #7
It sounds to me like a poor connection someplace, as others have mentioned double check the ground connection and battery connections. Then start troubleshooting with a test light or volt meter that current is getting to the switch, thru the switch in the on position, to the dash lights, etc. I am sure you will find a loose or dirty connection pretty quickly. Check any electrical harness plugs and connectors for dirt, corrosion etc.
/ L4610 wont start #8
I'd agree that's high on the list here. There's also a safety switch on the clutch pedal with the L10's. Clutch needs to be fully depressed to start.
/ L4610 wont start #9
The various safety switches though should not have any affect on the dash lights that came on for a second and then went off. The seat switch, clutch switch are easy enough to bypass to test or simply put an ohm meter on it.
/ L4610 wont start #10
Check the fuzable link near the starter. They usually are a pink or red plastic cartridge above the starter.
Lewis
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
