Tires L4330
/ L4330 #1
tcmike
centrial NY
L4330
Hi Folks!
I have not been here in years but thought of TBN while researching a tire issue for my 2004 L4330dt. It has 8-16 R-1 front tires. They are too narrow and sink into soft ground especially with the bucket loaded. I need wider tires.
After a lot of research I found a R-1 tire that is wider but the same hight (diameter) as the 8-16.
The problem I have now is how do I find wider 16" wheels to fit the tires - lug pattern- off set of my tractor?
Anyone know of someone that makes wheels?
Sorry, I left the tire size home - I'll post it tomorrow.
Thank you.
Mike
/ L4330
The tire size I found is 280/70r16 Michelin Super 8L. I need a 9 inch rim.
/ L4330 #3
You need to 'start' your search with the known dimensions of your present wheel. Your factory rim is: 6 bolt hub
Bolt Circle 6"
Pilot Hole 4.625"
0 offset
5.5" wide...
I think you will have no problem finding that rim in 8 inch or 10 inch width.... KennyV
2006 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2006 MAC 35ft...
KUBOTA L5030 TRACTOR (A65054)
KUBOTA L5030...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
13ft. Dump Trailer (A64556)
13ft. Dump Trailer...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
