L4240 upgrades
/ L4240 upgrades #62
/ L4240 upgrades
Sounds like a Troll to me. Very negative, bad attitude, very rude, no pictures, very limited info on why his tractor wont do the work.
He also won't answer and questions are take any advice.
@ OP, nice upgrades.
On the 12V mod, what connector did you end up splicing in? I get how you tapped the power, just not what the end connector was.
Thanks.
You need to find a wire that is hot all the time, and get a fuse holder and I scotch locked it. Then find the wire going to the 12v power port and do the same. I connected the 2 with the fuse holder.
On the BX I just used a couple of fuse taps and a short piece of wire. Find a fuse that is hot all the time and run it to the 12v power port fuse. On the BX you need to blow the fuse that is in the 12v power port spot or everything will be hot all the time.
Here is what the one on the BX looks like.
http://www.tractorbynet.com/forums/kubota-owning-operating/257252-bx2360-upgrades-2.html
/ L4240 upgrades
I made a mag lite mount. I mounted the Mag lite mounts to a piece of aluminum. I used 2 exiting holes in the tractor with tread sets and bolted the mount to the tractor. I still may paint the mount.
/ L4240 upgrades
I was telling Scooby074 that I wanted to insulated the tractor. He suggested using foil insulation. I did some research and found that people had been using it on their car when they upgrade the stereo. I got some Reflectix double reflective insulation. It is available at Lowes. So far I have only added Reflectix to the floor and roof. I am hoping it will help keep some heat out. So far it seems like it has helped but I need to use the tractor some more to be sure.
First half cut out. I laid the scraps agianst the rubber mat to see how good the fit was.
Cutting out second half.
Second half cut out, getting ready to tape together.
Taped together.
Installed in tractor.
The cab top.
/ L4240 upgrades
The Kubota L40 tractors (maybe all Kubotas) sold in North America do not have brake lights. They are wired for brake lights and have double filament bulbs, they just do not have a stop light switch under the dash. I got a stop light switch for a 1978 Ford F-150. It fits right in place where the switch should be.
Here is the switch, it came with the wiring.
Here it is installed.
Now I have the first Kubota L40 tractor in North America with brake lights:cool:
/ L4240 upgrades #68
Kioti's come with working brake lights.:laughing: sorry couldn't resist!
/ L4240 upgrades #71
Nice work, 94BULLITT, whats that pedal on the left side for?
/ L4240 upgrades #74
I'm confused, is that not an HST?
Many of the Kubota HST machines still had clutch pedals until some of the recent models. They used the dry clutch for engagement of the PTO instead of a hydraulic/electric clutch pack. Also usually a safety switch was activated by pushing in the clutch pedal for initial starting. It also sometimes makes range shifting a tad easier to push in the clutch to line up the gears to have the tractor move just a smidgen. But not entirely necessary to do that to change ranges. Many other brands of HST machines still have clutch pedals for the reasons given above, but many do not.
/ L4240 upgrades #75
Thanks, just learned something again.:)
/ L4240 upgrades #76
Like the Auto industry, leave no stone unturned to save a penny.
/ L4240 upgrades #77
(10) New CATERPILLAR Keys (A65579)
(10) New...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
1979 Ford 5000 (A64126)
1979 Ford 5000...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
