L3940 HSTC
/ L3940 HSTC #21
All you hear is the freeeking hydro whining worse than me obsessing over the whiny hydro. You can only hear the turbo at idle or high idle.
The straight pipe is temporary. I like quiet and will get it right, I need a muffler of some type.
Speaking of the hydro noise I see all the new Subaru CVT transmissions have a noise blanket around the top and sides to keep the "yayayayayayaayayayayayaya" noise from the consumer still paying on the 6 year NOTE. Maybe I could wrap a blanket around my hydro so I could hear the turbo better.
Fred
Another note too I removed the shim to get the pressure back to 2600 psi and the drop in RPM when using the hydraulics is almost completely gone (about 50 RPM drop).
/ L3940 HSTC #22
Aha, that answers that,. yeah that is about what I see with my similar sized Kioti.
Do you have any feel for how much HP you have gained with the turbo?
/ L3940 HSTC #23
Fred, just asking about that noise you hear. My 4240htsc was making a similar noise you describe. It was very very loud. To the point I thought I had made a mistake buying a hydro. Dealer picked it up and ended up shimming the cab up a little. Apparently something was touching.One of the loader lines was also rubbing on the frame. All that noise is gone. What I call just normal hydro noise now.
/ L3940 HSTC #24
Nice work, Sir!
Fred you can work on my tractor any time you want. :).
I'm impressed with your workmanship and I'm happy to hear it turned out well!
/ L3940 HSTC #25
Thanks all,
Feels like I added 25hp but no telling without checking it.
I'll check the cab to see if anything metal is close.
So far zero issues. Still does not start very well. Kept inside heated shop about 47 degrees. Let the glowplugs cycle once and it just doesn't start like my old Ciub Cadet left outdoors with a lower rad hose heater that I seldom use. That one starts down to 5 above witout plugging in.
My feeling is that if I left this 3940 outdoors it simply would not start below 30 above. Maybe it's me time will tell.
Fredjacker
/ L3940 HSTC #26
Thanks all,
Fredjacker
Do you know for a fact the glow plugs are really working? Did you measure the voltage on them and resistance of the plug to the block. The two Kubota's I owned in the past were all pretty easy starters, and the Kioti I have now is exceptionaly easy starting. One bump on the key is all it ever takes. Just an idea.
James K0UA
/ L3940 HSTC #27
Do you know for a fact the glow plugs are really working? Did you measure the voltage on them and resistance of the plug to the block. The two Kubota's I owned in the past were all pretty easy starters, and the Kioti I have now is exceptionaly easy starting. One bump on the key is all it ever takes. Just an idea. James K0UA
I second checking the glow plugs. My 5240 will fire on the first revolution down to about 14* (coldest I've tried so far), it does sputter and miss for a few seconds but it smooths out. Here is a video of mine starting.
/ L3940 HSTC #29
Thanks all,
Fredjacker
Still am convinced that it is a timing issue with these emission engines. 2 degree increase in timing will make a big difference but won't be an issue because of turbo charging. Most DI turboed engines are 19-21*. I realize this is an IDI engine but that also means you can run even more advanced timing.
Have do a boost pressure check?
/ L3940 HSTC #32
The L5240 starting is about exactly like my L5740 at 20 degrees, but that is no surprise since they have the same engine with the 5740 running an extra 100 rpm to get the additional power.
/ L3940 HSTC #33
I wish The Fred would start a new thread to bring us up to date. Maybe the self-righteous types could stay off of the thread long enough for us to learn how the build turned out.
Edit: I see The Fred and I were posting at the same time. Thanks for the update, Fred. Sounds like it was a big success. My hat's off to you for your persistence and tenacity.
Right !!!! Hats off to The Fred !!!
The Fred,
I am so glad this turned out for you. Maybe you can start a thread called "I still Love my Tractor"? As one of the "believers" from the beginning, I really like seeing these pictures and like hearing that the turbo has made a positive difference. Maybe you can go into business selling kits. Haha. Good Job !!
/ L3940 HSTC #34
Thanks all,
Fredjacker
Nice video Fred, it's great to see it running and read about your satisfaction. You should consider slightly rebadging that machine: like L3940 SHO, L3940 SS, or maybe the F3940.
/ L3940 HSTC #35
Fred,
I forget and I can't look it up due to the old thread being gone, but did you ever try it with new diesel?
/ L3940 HSTC #36
Fred,
He mentioned once that he did run some fresh diesel.
/ L3940 HSTC #37
Ok it didn't show up that time, let's try this again.
Kubota L5240 Cold Start - YouTube
Holy smoke.. literally. I remember seeing another GL starting, and it was similar I think, but it's been a while. Next time I have the L3400 outside I'll do a cold start video, just for comparison. I don't understand what's so different about these engines, other than injection timing possibly. It's calling for cold temperatures here over the next little while, so I should be able to get a decent video.
Funny, after watching the above video there's another one on Youtube of an ALCO locomotive engine doing a cold start. We used to have some of these in gate vessels, starting was always impressive in cold weather. About the only thing worse was some of our ex-British submarine engines in cold weather with a water-cooled exhaust. Looked like Vesuvius boiling over and smelled like.. well, something truly foul.
Sean
/ L3940 HSTC #38
I've only started my tractor down into the teens once, and I cycled the glow plugs twice instead of once, but it was nothing like that. It coughed for about two seconds and then ran fine. No smoke that I could see.
/ L3940 HSTC #39
Holy smoke.. literally. I remember seeing another GL starting, and it was similar I think, but it's been a while. Next time I have the L3400 outside I'll do a cold start video, just for comparison. I don't understand what's so different about these engines, other than injection timing possibly. It's calling for cold temperatures here over the next little while, so I should be able to get a decent video. Funny, after watching the above video there's another one on Youtube of an ALCO locomotive engine doing a cold start. We used to have some of these in gate vessels, starting was always impressive in cold weather. About the only thing worse was some of our ex-British submarine engines in cold weather with a water-cooled exhaust. Looked like Vesuvius boiling over and smelled like.. well, something truly foul. Sean
I should do a cold start video of my parents old B8200, it smokes for probably 30+ seconds but it is also a 25+ year old tractor. I really think if the timing was bumped up a few degrees on these egr engine the smoke on a cold start would disappear.
/ L3940 HSTC #40
Sean
It has to have something to do with the way these things are set up, our L5740 is like everyone else s, but out L5030 didn't smoke nearly as much and started much smoother.
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
UNUSED RAYTREE RMVR76 - 76" VIBRATORY ROLLER (A62131)
UNUSED RAYTREE...
2019 John Deere 835R Gator (A63116)
2019 John Deere...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
