L3940 GST transmission issue
   / L3940 GST transmission issue #1
okiecraig
Creek County, OKlahoma
1972 MF 135 diesel, Kubota L3940
Just completed first transmission fluid change at 400 hours as suggested by ops manual. Used Kubota UDT and filter. Now the tractor has a little "jerk" each time I put it in gear that it did not have previous to changing fluid. I can use the clutch and eliminate the "jerk" but that seems like a bad workaround that will cause unnecessary wear on the clutch.
Any ideas?
   / L3940 GST transmission issue #2
i would take to my kubota dealer about your shifting prob.it could be something simple.
   / L3940 GST transmission issue #3
The Kubota GST transmission really needs Super UDT for the best function and shifting. The GST ECU shifts gears and modulates the solenoid for the shuttle clutches for smooth shifting and is made to work with the Super UDT.
When I did the 50 hour change on my L3130GST that came with a used backhoe that had some other fluid in it, the UDT change made it run smoother and got rid of a little clutch squeal in 7th and higher gears.
There should be GST clutch setting mode in the Intellipanel but it is made for when the solenoid is changed and not really to compensate for the incorrect fluid. The GST has a temperature sensor and speed sensors for shifting and am thinking it is being thrown off by the change from Super UDT to UDT.
David Kb7uns
2013 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2013 FREIGHTLINER...
2019 BOBCAT T450 SKID STEER (A60429)
2019 BOBCAT T450...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
