L3901 Weight Question
/ L3901 Weight Question #1
jedclark
Nashville TN
none
I'm sure I am simply overlooking this in a brochure, but what is the weight of a L3901 w/ a 525 loader? The tractor alone weighs around 2600lbs. (?) But what is the added weight of the loader?
/ L3901 Weight Question #2
LA525 FEL is 845 pounds by itself. Bucket adds around 160 pounds additional.
You have to tease the FEL weight out of the Kubota Whole Goods catalog.
2,600 pounds for 2-WD, gear transmission L3901.
Most who order an FEL would have 4-WD + HST. That bare tractor weight is 2,778 according to Kubota.
Tractors are spec'ed with R1 tires. Add 150 (+/-) pounds for R4 tires, which most would order with FEL.
Perhaps 50% of compact tractors depart the dealer with filled rear tires, which would be additional weight. Weight will vary by tire size, fill liquid and fill level.
So a L3901HST R4 w/525 FEL and bucket weighs at least 3900#? And Jeff thank you for the ultra-fast response.
/ L3901 Weight Question #4
I figured my L3200 (same machine, less HP & emissions) was around 3,500lbs with loader & loaded tires, never validated that. If you really need to know hit up your local gravel yard or some place with a big scale. They usually let you weigh stuff for free as long as you don't block sales traffic & are courteous.
/ L3901 Weight Question #5
Loader weight includes the bucket.
Doubt 4 ply R4 adding 150 lbs as they weight less than 130Lbs each. L3901 is too light, load the tires to get it to weigh +4,000 lbs.
3 Bottom Plow (A62613)
60in. Work Bench (A65640)
60in. Work Bench...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
