L3901 Weight Question
/ L3901 Weight Question #1
jedclark
Nashville TN
none
I'm sure I am simply overlooking this in a brochure, but what is the weight of a L3901 w/ a 525 loader? The tractor alone weighs around 2600lbs. (?) But what is the added weight of the loader?
/ L3901 Weight Question #2
LA525 FEL is 845 pounds by itself. Bucket adds around 160 pounds additional.
You have to tease the FEL weight out of the Kubota Whole Goods catalog.
2,600 pounds for 2-WD, gear transmission L3901.
Most who order an FEL would have 4-WD + HST. That bare tractor weight is 2,778 according to Kubota.
Tractors are spec'ed with R1 tires. Add 150 (+/-) pounds for R4 tires, which most would order with FEL.
Perhaps 50% of compact tractors depart the dealer with filled rear tires, which would be additional weight. Weight will vary by tire size, fill liquid and fill level.
So a L3901HST R4 w/525 FEL and bucket weighs at least 3900#? And Jeff thank you for the ultra-fast response.
/ L3901 Weight Question #4
I figured my L3200 (same machine, less HP & emissions) was around 3,500lbs with loader & loaded tires, never validated that. If you really need to know hit up your local gravel yard or some place with a big scale. They usually let you weigh stuff for free as long as you don't block sales traffic & are courteous.
/ L3901 Weight Question #5
Loader weight includes the bucket.
Doubt 4 ply R4 adding 150 lbs as they weight less than 130Lbs each. L3901 is too light, load the tires to get it to weigh +4,000 lbs.
HEIN-WERNER 57 SERIES 2 BUMPER JACK (A65643)
HEIN-WERNER 57...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
DooLittle XTM-8418 Trailer (A66285)
DooLittle XTM-8418...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
