L3800 HST Rear Remote Hydraulics
   / L3800 HST Rear Remote Hydraulics #21
I hear you, my current setup isn't ideal, but is way better than it use to be. Imagine crowding that with a quick hitch now. :p
   / L3800 HST Rear Remote Hydraulics #22
Crowded with a quick hitch? Na, it's not that bad..... Just added the hyd toplink yesterday. Even with all this, I still have room for my 6' 2" and 245 lbs self in there running the backhoe
   / L3800 HST Rear Remote Hydraulics #23
20150328_152950.jpg20150328_153007.jpg20150328_153021.jpg20150328_153038.jpg20150328_153052.jpg
Thanks to Brian at fitrighthydraulics
I could not live without it, it really made a tractor out of it.
   / L3800 HST Rear Remote Hydraulics #24
Quick question: I am getting rear remotes put on my MX5100. I have ordered from the dealer 2 rear remotes one with detent(float), one without. Someone told me they recommended both with detent. other options would be welcome.
   / L3800 HST Rear Remote Hydraulics #25
Depends on what you are planning to do... and there are ways around not having float. I don't have float on any of my valves. When I bush hog, I just don't connect the top link. The few times I hit rocks, just lifting the front of the mower is enough to clear the rock. For me, I just don't see the need for float.
   / L3800 HST Rear Remote Hydraulics #26
Float is a 4th position. You can still use the valve like normal, as if the float wasn't there. But you still have it if you want. Same cannot be said for a standard 3-position valve.
   / L3800 HST Rear Remote Hydraulics #27
You can take my float from my cold dead hands...
Don't use it much on my side link, but all the time on my toplink.
   / L3800 HST Rear Remote Hydraulics #28
Circumstances are the key here. I have only used float on the top link checking different situations out. Side link gets used every time I do a complete smoothing finish grade of our 1 3/8 mile road at every intersection.
2001 Ford F150 (A50121)
2001 Ford F150...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2012 Pinehill Gooseneck Trailer (A51572)
2012 Pinehill...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
