L3800 HST Rear Remote Hydraulics
/ L3800 HST Rear Remote Hydraulics #21
I hear you, my current setup isn't ideal, but is way better than it use to be. Imagine crowding that with a quick hitch now. :p
/ L3800 HST Rear Remote Hydraulics #22
Crowded with a quick hitch? Na, it's not that bad..... Just added the hyd toplink yesterday. Even with all this, I still have room for my 6' 2" and 245 lbs self in there running the backhoe
/ L3800 HST Rear Remote Hydraulics #23
20150328_152950.jpg20150328_153007.jpg20150328_153021.jpg20150328_153038.jpg20150328_153052.jpg
Thanks to Brian at fitrighthydraulics
I could not live without it, it really made a tractor out of it.
/ L3800 HST Rear Remote Hydraulics #24
Quick question: I am getting rear remotes put on my MX5100. I have ordered from the dealer 2 rear remotes one with detent(float), one without. Someone told me they recommended both with detent. other options would be welcome.
/ L3800 HST Rear Remote Hydraulics #25
Depends on what you are planning to do... and there are ways around not having float. I don't have float on any of my valves. When I bush hog, I just don't connect the top link. The few times I hit rocks, just lifting the front of the mower is enough to clear the rock. For me, I just don't see the need for float.
/ L3800 HST Rear Remote Hydraulics #26
Float is a 4th position. You can still use the valve like normal, as if the float wasn't there. But you still have it if you want. Same cannot be said for a standard 3-position valve.
/ L3800 HST Rear Remote Hydraulics #27
You can take my float from my cold dead hands...
Don't use it much on my side link, but all the time on my toplink.
/ L3800 HST Rear Remote Hydraulics #28
Circumstances are the key here. I have only used float on the top link checking different situations out. Side link gets used every time I do a complete smoothing finish grade of our 1 3/8 mile road at every intersection.
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
AGROTK YC-32G Horizontal Band Saw (A60463)
AGROTK YC-32G...
2024 Linx Trailer (A60462)
2024 Linx Trailer...
2020 DRAGON ESP...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
