3-Point Hitch L3710 3 Point Hitch Hand Crank Problem
/ L3710 3 Point Hitch Hand Crank Problem #1
lion12
Stowe, VT
Kubota L3710
The hand crank on my L3710 used to rotate the 3 point hitch will only move a couple of turns. Has plenty of grease. Any suggestions on how to fix it? Thanks.
/ L3710 3 Point Hitch Hand Crank Problem #2
maybe clean off the grease and see if the threads look damaged. Or the threaded part could be bent. I am dealing with a similar issue, where I actually removed mine and put in a vise to unthread completely so I could replace the thrust bearing in the gearbox. It was very difficult to do and I must have actually damaged the threads enough in this process that a couple months after putting it back together I actually had the threads pull out of the bottom part and the right side of my mower deck fell to the ground then when I lowered it I bent what was left of the threaded portion.
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
gps trailers (A56859)
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
(INOP) 2012 FREIGHTLINER CASCADIA DBL SLEEPER ROAD (A60430)
(INOP) 2012...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
