L3540 hydro power questions
   / L3540 hydro power questions
Do you change your HST fluid and filters according to the manual. I don't recall if you changed your fuel filter.
I buy fuel, 6 five gallon cans and then dump it into my TSC 50 gallon cube with a TSC electric pump. I have a 10 micron filter on my pump. Now both my L3540 and my B7100 fuel filters stay clean for a long time.
I don't pretend to be a mechanic, have you talked to the dealer. Sometimes they will talk to you on the phone and maybe solve the problem.
Yes, I changed my HST fluid filters and the fluid as per the manual looking at my fluid. I can hardly see it on the stick because it’s so clear. The fuel filter was changed not too long ago and I just re-cleaned it and the air filter as well..
   / L3540 hydro power questions #92
I’d be looking at the pickup tube. I have had them freez and crack with water in the fuel. If it is cracked near the bottom it may be sucking air when you tilt one way or the other.
My thought there would be if it was cracked it would be leaking and it is not. But thanks for the suggestion.
   / L3540 hydro power questions #94
he is talking about the pickup tube in the tank you wouldn't see a leak since it is on the suction side and inside the tank. does it do it more often with less than 1/2 a tank of fuel.
It does not seem to make a difference how much fuel in the tank.
So I have a front axle seal gone out so I’m taking it to the dealer for that and see what they think on the loss of power. Tired of messing with it.
   / L3540 hydro power questions #96
I have an axle seal on mine too left side. I'm thinking I will try gear oil instead of SUDT2 before tearing it down. Have you replaced the lift pump or at least taken it off and checked it visually.
My tractor does not have a lift pump on it. I have a short section of piping may be a foot and a half long and runs from the bottom of the tank right to my fuel filter.
So I finally decided to take it to the dealer, with a bad seal and the loss of power I figured I’d just let them play with it. IMG_5422.jpeg
   / L3540 hydro power questions #99
i thought we didn't have one too but I think you should have one. i think it is mounted on the injection pump. it is after the filter
Ahh, what am I looking for? Do you have a picture?
1325 (A58374)
1325 (A58374)
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
FORKS (A52709)
FORKS (A52709)
2001 Bobcat 873 Compact Track Loader Skid Steer (A56857)
2001 Bobcat 873...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2003 Big Tex 10PI...
