L35 Thermostat Replacement
/ L35 Thermostat Replacement #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
Finally getting around to a new thermostat on my L35. Hope it fixes a low engine temperature problem I'm having.
Question about the gasket. It is a plastic-like material that has a pressed-in indent following around the circular hole of the thermostat manifold. So the gasket is flat except for this small circular indent. On one side this 'notch' is an indent as said, on the other side of the gasket it is a corresponding pop-out.
Sorry if I can't describe this simple thing very well.
Does the pop-out side of the gasket face the engine, or does it face the top cup which encloses the thermostat?
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
PITTSBURG 2R CULTIVATOR FRAME (A64278)
PITTSBURG 2R...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
3145 (A63117)
3145 (A63117)
JOHN DEERE 1770NT - 12R30" VACUUM PLANTER (A64278)
JOHN DEERE 1770NT...
