L3400 vs Grand L3130
/ L3400 vs Grand L3130 #1
tucan
Hancock,Maine
Kubota Grand L 3131
We have finally narrowed the choices down! Our dealer has offered us a L3400 for $16,290 (8 forward, 4 reverse)and the Grand L3130 (8 forward gears, 8 reverse) for "a special deal "of $16,686. We have decided, whichever machine, to order the BH80XT and the Salsco 627 chipper. We currently have two 3 acre sloped properties needing some earth moved stumps pulled and general landscaping chores performed. Then, there's a retirement piece that eventually will need a real road made from an exising logging road, fortunately it comes with it's own gravel pit and we have the luxury of time to do the upgrades. One of the largest deciding factors is we prefer the "simpleness" and classic look of the L3400, and wonder if, for the money, the Grand L3130 would be worth it. Any and all input would be appreciated. Thanx
/ L3400 vs Grand L3130 #3
You don't mention what loader you're considering on the L3130. The LA723 makes the L3130 worthwhile with its superior lift, reach and curl angle.
/ L3400 vs Grand L3130 #4
The loaders in question for the L3400 and L3130 are LA 463 and LA 513 respectively. I also failed to mention that each transmission was DT. Thanx again!
/ L3400 vs Grand L3130 #7
For me, there would be no choice. All the 3400 has more to offer is 2hp. The 3130 is better all around, in lift, comfort, shuttle trans and extendable links, for a few hundred more? Go with the 3130, you won't be sorry. My .02, mp
/ L3400 vs Grand L3130 #8
/ L3400 vs Grand L3130 #9
What is BH80XT and how much does it cost? How much was the Salsco 627 chipper? I am also considering L3400 w/ FEL (LA 463) and backhoe (BH75). Thanks
/ L3400 vs Grand L3130 #10
BH80X is the "Woods" brand backhoe, the "T" represents the optional manual thumb (together quoted at $7500) and the Salsco 627 chipper is gonna run $3100.
/ L3400 vs Grand L3130 #13
I will echo cheesehead in that you get the LA723 loader and also a heavy duty bucket. Since you will be doing a lot of digging and spreading of gravel the combination will pay off in the long run. The bolt on cutting edge is optional, it just saves wear on the bucket edge which is already fairly heavy. A toothbar might be of greater value.
Vernon
/ L3400 vs Grand L3130 #14
Vernon
/ L3400 vs Grand L3130 #15
I have a L3400 and the price difference between my machine and a L3130 (both hydrostatic) was about $2000. That was not with the LA723 loader either.
$2000 was too much for me as I was past my budget $10k ago!.
However, if it was a difference of hundreds (or even $1K), there is no question - I would have gone with the L3130. Its a mighty fine machine. You will appreciate the extra weight and other extras.
Do yourself a favour and definately spring for the LA723 loader though. Worth every extra dollar you will spend for sure.
/ L3400 vs Grand L3130 #16
/ L3400 vs Grand L3130 #17
I would get the 3130 with the 723 loader (4 or 5 hundred more than the 513 but well worth it) and a bolt on toothbar. The standard bucket has worked fine for me and that loader is great. Load the tires and the 3130 will really hook up and get it done.
/ L3400 vs Grand L3130 #18
/ L3400 vs Grand L3130 #19
tucan, I just wanted to mention here (in case you hadn't seen it in another thread).....
I'm being quoted 17,800 for that same 3130 config you're talking about. (with loaded r4's)
I wish I had all the data in order in front of me, I'd post the capacity of each loader so you could see why you're being directed toward a 723. For 800 to 900 bucks you could get the Quick Attach bucket in addition to the loader upgrade.
If our dealers prices were as aggressive as yours, I might not be buying a Massey.
/ L3400 vs Grand L3130 #20
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2019 CATERPILLAR 950M WHEEL LOADER (A60429)
2019 CATERPILLAR...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
F -550 Bucket Truck (A61306)
F -550 Bucket...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
