L3400 pto frozen in gear
   / L3400 pto frozen in gear
Don't know if this would help or not, you can lock the clutch pedal down. Not sure if that might help pull the clutches apart or not.
Yes, can lock down the clutch pedal. [Since I screwed up and let it sit with clutch engaged for two years, leading to this problem ...] NOW... I use the pin/spring thing on the pedal to disengage the clutch every night - or whenever the tractor is parked.
Plus for last 2 days, I rock the tires every night (engine off - clutch locked down - in high gear - PTO engaged) to try and get the PTO secondary clutch to let go.
This worked to free the main clutch. Now hoping it works on the PTO clutch.
JOHM DEERE 1600 WAM LOT NUMBER 125 (A53084)
JOHM DEERE 1600...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
100 Gal Fuel Tank with Pump (A51573)
100 Gal Fuel Tank...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
TEST YOUR BID BUTTON! (A51247)
TEST YOUR BID...
