L3400 pto frozen in gear
   / L3400 pto frozen in gear
Don't know if this would help or not, you can lock the clutch pedal down. Not sure if that might help pull the clutches apart or not.
Yes, can lock down the clutch pedal. [Since I screwed up and let it sit with clutch engaged for two years, leading to this problem ...] NOW... I use the pin/spring thing on the pedal to disengage the clutch every night - or whenever the tractor is parked.
Plus for last 2 days, I rock the tires every night (engine off - clutch locked down - in high gear - PTO engaged) to try and get the PTO secondary clutch to let go.
This worked to free the main clutch. Now hoping it works on the PTO clutch.
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
