L3400 PTO Cable
/ L3400 PTO Cable #1
mjfox6
NE Mississippi
2005 Kubota L3400 HST
Just so it is documented, the PTO cable on my L3400 (170 hours) did not disengage this weekend.
I was checking out the tractor and bushhog to get ready for the upcoming season. I had a long list of things to do, the last being lubricate the PTO cable since I had never done it. I was on the second to last one, adjust the slip clutch, and when I engaged the PTO to slip the clutch, it would not disengage. It appears the cable kinked and did not go back into the sleeve. I was able to guide it in with my other hand and get it to shut off.
I pulled back the dust cover and spayed it with silicone, then moved in back and forth. I climbed under the tractor and did the other end of the cable since I was doing it.
I used the bushhog for a few hours yesterday and was able to successfully shut the PTO off every time without an issue.
The moral of the story...Move lubricating PTO cable to the top of your list! I plan on doing mine every 10 hours, when I lubricate the bucket and bushhog. I hope that is often enough.
/ L3400 PTO Cable #2
Your kind of working from behind. I'd stay on the ten hour program for a while but when it starts working easier you could cut back.
/ L3400 PTO Cable #3
mjfox - thanks for posting this.. I've got a 100 hrs on mine and I haven't lubricated it yet. I've been meaning to - just don't remember to do it. Your post has reminded me to make this a priority.
This is basically a spray on lube that you are applying ? Where did it kink? Where are you lubing it - by the engagement lever?
/ L3400 PTO Cable
This is the spray I used: Teflon Silicone Lubricant - 10 Oz. Aerosol
It kinked right below the engagement lever. Like I said, I was able to use one hand on the lever and one on the cable to keep it from kinking and get it to shut off. To lube it, I pulled back the dust cover and sprayed in the lubricant. Then, I moved the engagement lever back and forth several times and then sprayed it again.
I also found the other end of the cable and lubricated it as well.
/ L3400 PTO Cable #5
I'm at 165 hours so I guess I'd bet get to it.
I went out and looked at the cable and If mine needs replacement I think I will get one of my mechanical engineers to design a lever to replace the cable. The shroud that covers the area under the seat could be laser cut to allow a lever to protrude through the front. No more cable. That would put the PTO lever about the same place it is on my 1910. I would cut the shroud so that it would lock on and off to prevent bumping it with my foot. The lever might also be able to protrude through the top of the shroud and be out of the way of a foot.
With the cable gone there is not a chance of stretching or cable mis-adjustment which can be catastophic for the clutch.
This whole cable idea is not what I consider good engineering. Kind of like a flat roof, Just a matter of when.
/ L3400 PTO Cable #6
Kubota has changed the PTO cable brackets due to frequent PTO cable failures, my L2800 has had two cables replaced, the last time they also put the new style bracket on it. 165 hours on it now. If your L2800/L3400 has a PTO cable failure and you are still under warranty tell the dealer you want the bracket replaced.
/ L3400 PTO Cable #7
ccsia - I completely agree. Surprises me that Kubota also uses this on the Grand L 3240s.
You sure you don't wan't to produce a bunch of these levers for the rest of us :)
/ L3400 PTO Cable #8
If I have to do it I will document it. I could see making the parts available. Cutting the shroud would be the worst part. Could be done with a sablre saw though.
Marcussen,
I am trying to envison how a different bracket makes the cable more reliable. Can you tell us how this new bracket is different and which end of the cable gets the new bracket.
/ L3400 PTO Cable #9
Marcussen,
The bracket on the lever end is changed so the angle is reduced between the movable lever and the bolted bracket, both of my cables that was replaced was kinked in this area. Only time will tell if this realy fixes the problem or not;) , but it looks like it should help anyway.
/ L3400 PTO Cable #10
Thanks Marcussen: I see what they are doing there now. The force vector will be more in line with the cable instead of from the side. That sure should help.
/ L3400 PTO Cable #11
Mine is an 06' 2800. I have posted pics of my cable and bracket. The first is disengaged, the second is engaged. I have never had the bracket replaced. I can't see how the angle could be made any better on mine...it's pretty much a straight shot. Do I have the new bracket?
Secondly, I can't seem to get the boot pullet back to lube the cable. It is a crimped type nut on the top of the boot, so I assume I should just wrench on the bottom part of the boot to get it pulled back and it pops off?
/ L3400 PTO Cable
MDM,
Move the lever to the engaged position, this will stretch out the boot. Then, you can slide the forward side of the boot towards the rear of the tractor, which will expose the cable and sleeve.
I also lubricated the bearing pin eye that is attached to the lever, it has to swivel to help align the cable and sleeve.
Hope this helps.
/ L3400 PTO Cable #13
MDM: I cannot tell for sure trying to compare your picture to my lever but it looks like you may have less angle than mine. Marcussen can probably answer better.
The boot just pops off, no wrenching needed. It pops off the cable end. Put in the lube and then force it back onto the cable end.
/ L3400 PTO Cable #14
Can anyone comment as to whether the pictures above are of the newer bracket?
/ L3400 PTO Cable #15
Photo of my 2005 bracket. Looks to be the same. I have a slight bend on the other end of the cable.
(PS. for those that saw the "on" and "off" in the wrong place, that's to keep stupid criminals from steeling my tractor)
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2016 Ford F-150 Extended Cab Pickup Truck (A64557)
2016 Ford F-150...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A67714)
ALLMAND ECOLED-RIG...
Travel Trailer (A66738)
Travel Trailer...
2009 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
