l3400 HST power questions
   / l3400 HST power questions #1
grizzjeeper
Bronze Member
Fairfield Maine
Kubota l3400 HST
My l3400 HST seems low on power, I guess I am looking for some reasurance. There are plenty of times when I could easily stall the engine in Low range at pto throttle doing loader work. I feel that with 34 HP I should be spinning the wheels. The terrain is usually a mud/clay with a fairly hard bottom. I am glad I didnt get a smaller unit.
Is mine underpowered? Seems like it has less power now then when I first got it. 33 hours on it now.
   / l3400 HST power questions #2
I have an L3400DT, so I can't compare it to the HST, but I don't have any power problems as you describe. I will lose traction before I would stall... I can push a lot of dirt at 2000rpm, and it still has plenty of power.
Sounds like you might be having a problem, especially since it seemed like you had more power when it was new...
   / l3400 HST power questions #3
Hello grizzjeeper,
This is typical of a hydro tranny. You may want to try a toothbar to help the loader work. MJK
   / l3400 HST power questions #4
If your trying to dig up unbroken ground then yes it will be easy to stall the motor.
2015 Ford Fusion Sedan (A50324)
2015 Ford Fusion...
Chery 10' 18 Drawer Workbench (A50121)
Chery 10' 18...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
5' ATV Harrow (A50515)
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
