L3400 DT hydraulics Q
   / L3400 DT hydraulics Q #1
praha
Chicago suburb
Kubota L3400 gear
there's a couple of plugged opening/holes in a black hydraulic hose block/hydraulic valve? What are they for///extra auxilliary outlets usable for a grapple??, possibly??
Can I use these outlets for an el. grapple valve supply ?
I obviously know nothing about hydraulics, but I need a grapple , so I have to get educated....and do it.
Thanks,
Joe
Thanks Kenny,
I want to buy some grapple hydraulic controls from Wikco....and they needed to know this.
Joe
   / L3400 DT hydraulics Q #4
Joe
if they are in fact aux. hydraulic ports you will not need any additional controls. You have the control valve there for that set of aux ports ?
Kenny,
I need to control a grapple arm somehow, up and down movement. I need a joystick or just a switch.....?
Joe
   / L3400 DT hydraulics Q #6
You can decide for yourself whether you want an additional joystick or a switch that operates from your existing joystick. On my L3400 I plumbed in an additional joystick for my grapple. My guess based on year old research is the switch will run you more money than another stick. Either way you go will work. Numerous owners have done this. I went with a tatro grapple which is a smaller two finger design because in my opinion a lot of additional weight up front was not desireable.
   / L3400 DT hydraulics Q #7
Joe.
If you have aux hydraulic ports you would not need an electric valve, this is normally used if you do not have, and do not want to add remotes. It gives you a split function of one of your loader circuits, usually the curl. (it is cheaper than installing remotes).
If you already have remotes all you need to do is plumb the ports from the rear to the front of your tractor. You can do this with hydraulic hose. The control is with the valve that activates the rear remotes it is already there. It's beside your seat but not really unhandy.
Typically a joy stick is used for two cylinder valves. Since a grapple is a single valve circuit I don't see what would be gained over a single lever control. KennyV.
Ken,
I am confused a little. How am I gonna control a grapple cylinder? /clamp/
Joe
Wayne,
I'll check tatro grapple. Will joystick be more reliable?? Or will switch be easier to operate? Where did you get these parts? Its not AG land/bus around here, so I am buying everything on the Net.
Joe
Kenny,
one thing more, it is my lock of knowlege and this specific terminologie, which got me confused. I am grateful for you help!!!! I will have to do a homework first. It may not be as complicated as it seems, but like everything else, easy, when you know what and how to do...anything.
thanks,
Joe
New Holland 474 Haybine (A50774)
New Holland 474...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2013 JLG G9-43A Telehandler (RUNS) (SMOKES) (A50774)
2013 JLG G9-43A...
P.T Farm Wagon (A50121)
P.T Farm Wagon...
Tri-Axle Police Travel Trailer (A51694)
Tri-Axle Police...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
