L3400 cutter size
/ L3400 cutter size #2
I use a ford 951a 6ft rotoey cutter on my 3400 and do some wet marsh grass 1-2ft tall. Never had a problem.
/ L3400 cutter size #4
I have a L3400HST with a 5ft woods cutter and if I were to buy again I would go with a 6ft for sure.
I'm not cutting through anything incredibly thick here but doubt it would make a difference. And I plan on always having my loader on for mowing anyway.
/ L3400 cutter size #5
I have a 72" Woods finish mower and a 3400HST, no problems at all even in high range. /forums/images/graemlins/grin.gif
/ L3400 cutter size
Thanks Solo and thanks all, very helpful. Anybody else?
/ L3400 cutter size
Canoe,
Are u happy with the 3400 overall. I'm considering one.
/ L3400 cutter size #8
I've decided on a 72" RFM for mine, but, I'm still unsure weather a 60 or 72" rough mower is what I want. I may go for the 60" just to be able to tackle the larger deeper stuff on the property.
But I'll be watching and listening to anyone with input on this.
/ L3400 cutter size #9
I run a 60" brush hog and a 72" Woods heavy duty finish mower. No problem at all. Plenty of power.
I think the only issue with a 72" brush hog is I'd probably need some front end weights since I don't have an FEL on my L3400HST.
/ L3400 cutter size #10
I have a 60" and wish I had larger because the 60 is just wider than the track and makes it difficult to mow down fences and close to other things. With the loader off makes it easier but still slow.
James
/ L3400 cutter size #11
Hi Tom:
I'm very happy with the L3400. Bear in mind I only have about 3 hours mine - mostly trying to get accustomed to using a loader - turning the pile of manure over etc.
Nice machine at a very nice price. Lacks a few bells and whistles that I think I will be fine without. I don't need mid pto. Electrohydraulically activated PTO sounds cool but using the clutch to engage the PTO doesn't sound like much work to me either. Few other that would be nice to haves that can be found in the more expensive models from Kubota and the competition.
/ L3400 cutter size
Canoe,
Thanks for the feedback. I'm coming out of an old Long so I'm not to used to frills.
/ L3400 cutter size #13
At the advice of my dealer, I put a 84" Bush Hog finish mower on my L3400.
Cuts well, but is a bit too heavy if mowing with a FEL attached.
That said, you must be careful if mowing without FEL. Some weight in the front end would be welcome when the mower is raised. 100-200 lbs should be fine.
The 84" Bush Hog is a bit heavier than the Kubota manual would like hanging off the 3pt, and when raised, takes a lot of weight off the front wheels.
Good Luck
brande
/ L3400 cutter size #14
TomKioti said:
Canoe,
A few weeks after my machine was delivered, the Kubota rep. was out at my farm looking at the jerky 3PT value (their service was impeccable) and he pointed out to me that the reason they brought out the L3400 as a basic tractor was because they found that any one looking at a 10 yr or so old machine with about the same HP was paying close to what they could price a new no frills machine at.
They hit the market dead on if you ask me. I was one of those guys looking for a 10 year old machine and most of what I could find was priced within $5K or so of the 3400 and had as many or fewer bells and whistles as the L3400.
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-250...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61573)
2015 Hyundai...
2018 Ford Escape SUV (A61574)
2018 Ford Escape...
