L3400 Attachments
/ L3400 Attachments #1
Av8r3400
Platinum Member
North Central Wisconsin
Kubota L3400DT
My new L3400DT is on the way. Thanks for the input weather you added to the thread or posted years ago that I found using searches. Thanks.
To the L34xx owners out there: What size rough cut mower, box blade and finish mower would you recommend or have you used with good or bad results. I will be rough cutting mostly field grass (very little woody material), general use box blading, and finish mowing 3-5 acres when the house is done. (BTW - R4 tires and FEL on the tractor)
I'm leaning toward a 60" Box Blade and a 72" finish mower (next year). The rough cutter is where I'm really torn. I don't want to start a brand discussion, just a size discussion.
Thanks! /forums/images/graemlins/grin.gif
/ L3400 Attachments #2
I have the L2800 and recommend a BB with at least 65" width to cover your tracks, here is a link to pics of two different BB's on my L2800. Look under My Album.
The Bush Hog brand was the first one I used on the L2800 and is good quality and worked well, I upgraded to the Cammond for the hyd scarfiers and it is a beast.
My picture site.
/ L3400 Attachments #3
I have an L3410. You can easily handle any 60" cutter. Probably a 72" is ok given your listed use of little woody stuff getting cut.
jb
/ L3400 Attachments #4
If you are going to be rough cutting down a lot of fence line or around many other objects I would go with a 72".
I have a 60" and even with the FEL off it is tight mowing the fencelines.
James
/ L3400 Attachments #6
Congratulations on your new machine! I hope you love it as much as I do mine. 72" RFM and 60" rotary mowers are working very well for me.
/ L3400 Attachments #7
I just got my L3400HST a few weeks ago (also w/ R4's and FEL). I bought a Woods RD72 finish mower and it works great.
/ L3400 Attachments
You guys with the RFM's have any problems with the weight of the tractor/deck combo causing rutting? How about the R4's tearing the sod apart?
Thanks again.
/ L3400 Attachments #9
My experience was that the R4's left some damage to the turf, but not nearly like what my skid steer does (imagine that). I am told that turf tires will leave no damage as long as the ground is hard enough to ensure that they float and leave no ruts. I picked up a set of turf tires late last season, but have yet to try them out. This on a Kubota Grand L3830.
Ed
/ L3400 Attachments #10
I run a Woods RD7200 on my L3400 HST. No trouble with power. I have no problems with rutting using R4's. This depends a lot on what type of soil you have though. I have one low area when it rains a real lot that gets soft. I'm more careful about turning in there when it's wet.
But my lawn is "country". I don't have a story book lawn.
/ L3400 Attachments #11
My property is mostly flat so during winter and rainy spring I'm a little tentative driving my L3400 in certain areas but I had to do that with turf tires on a B2100 as well. So far no problems, I love the L3400!
/ L3400 Attachments #12
No question, my R4s will leave marks on wet soil...but then again, so will heavy boots. I have not found any trouble with marks or ruts during the typical grass cutting months when the lawn is dry enough to walk around on with just shoes on. I also try to avoid cranking the machine around in a tight corner with 4x4 engaged. Shawn
/ L3400 Attachments #13
Mine is on the way too so I have no experience but will share my selections. I went with a 60" BH with a 60HP gearbox. I do have some rough stuff to cut and wanted to be sure I would not tear it up. Also went with the R4s. If I had the money for a RFM, it would be a 72".
Hopefully mine will arrive next week.
2R ROTARY HOE, 3PT (A64278)
2R ROTARY HOE, 3PT...
2136 (A65055)
2136 (A65055)
2022 EZ-GO ELITE...
E-Z TRAIL HEADER CART (A64278)
E-Z TRAIL HEADER...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
UNUSED PARBREAK RB110-64" ROCK BUCKET (A65055)
UNUSED PARBREAK...
