L3240
/ L3240 #1
dave1132
I have a B3030 with a cab I have looked at the L3240 and like it but not sure it would be worth it to up grade Anyone know if there is that much difference?
/ L3240 #2
They are 2 different animals. The 3240 is much heavier with more frills. Depends what you want to use it for. Go to Kubota.com and compare the specs..
/ L3240 #3
I had a B7800 which I traded to a L3240HST which I traded to a B3200. The L3240 is twice the weight, sits a lot higher with much bigger tires, more FEL powerand capacity and has about the same HP.
What are you expecting the difference or upgrade to be?
/ L3240 #4
The B3030 compared to the Grand L 3240 is like night and day. As the others have said before me, weight and a much bigger sized tractor, it would be like comparing the B3030 to a SCUT. Now both are great tractor it just matters what your needs and tasks are, decisions, decisions.
DevilDog
/ L3240 #5
No question the L is much more tractor but also remember it has the same HP so it will seem underpowered for some tasks. It all depends what you need.:)
/ L3240
I am hoping for a little wider wheel base to have a backhoe on and I think the cab is roomer but I maybe better to put hoe on mine and save money
/ L3240 #7
If that is what you are after then the l3240 is much better.:thumbsup:
2015 KENWORTH T880 STAND UP SLEEPER (A63569)
2015 KENWORTH T880...
2020 PETERBILT 567 (A63569)
2020 PETERBILT 567...
VOLVO G720B GRADER (A63569)
VOLVO G720B GRADER...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
