L3130 Kubota, clutch problem?
/ L3130 Kubota, clutch problem? #1
nue2farm
Douglas County, Missouri
Kubota 3130
I went to move my tractor out of the barn. Everything was fine until I tried to put it in gear. I pushed the clutch petal in as normal but the tractor would not go into forward or reverse. I shut the tractor off and tried it, It felt like it went into gear either way. I tried again with it running and nothing.... ???? Any ideas? Suggestions? Thanks, Paul
/ L3130 Kubota, clutch problem? #4
The GST has two clutches, the main foot operated clutch and the shuttle shifter has a forward and reverse clutch pack. The transmission gets hydraulic pressure from the power steering section of the hydraulic pump to operate the clutch packs and also for shifting the gear selection forks of the transmission all controlled by the GST ECU unit under the left fender.
David Kb7uns
