L3130 3 Point hitch won't lower unless weighted
/ L3130 3 Point hitch won't lower unless weighted #1
U-B
I have a Grand L3130 with 110 hours. The 3 point hitch will not lower unless there is substantial weight on it - such as a box blade. The 6' rake is not heavy enough to lower it unless I stand on it for added weight. All fluids are at proper level and routine maintenance has been done. Is there a possibility that I have air in the system? And where would I bleed the system if air may be present?
/ L3130 3 Point hitch won't lower unless weighted #2
Is there a knob to regulate how fast it lowers? I know if I have mine set to lower slow and smooth with the implement, and then remove it, it wont drop on its own. Just a thought.Even with mine set to lower fast. It takes awhile for it to drop. I usually have to push it down .
Good Luck.
Sorry I could help for your particular model.
Al
/ L3130 3 Point hitch won't lower unless weighted #3
I also have a L3130. The previous poster is correct. There is a knob between your knees, below the seat cushion. You can turn the knob to adjust the how fast the 3 pt is lowered.
I keep the knob turned all the way in one direction, but sometimes my pantleg gets caught in it and changes it.
See if that works.
Thanks guys! That was my first thought also. The knob seems to be working, as the 3 point won't lower with me standing on it when in the closed position. It will lower in the open position with my weight added to the rake.
I should add that I weigh 290 lbs. so the added weight needed is substantial.:(
/ L3130 3 Point hitch won't lower unless weighted #6
That is odd. It should drop fairly quick empty with the knob turned all the way. Did you check the mechanism on the other end of the knob? Is there something going on there? I don't think it is air, but ?
jb
Well, the service manager at my local Kubota dealership says that this is normal! He says that many of the Kubotas the dealership has sold react this way when there is a "light weight" attachment on the 3 point hitch. They just tell the customer to add weight.......:confused:
/ L3130 3 Point hitch won't lower unless weighted #8
I have 525 hrs on my L3130 and it has never acted that way.
The arms lower all by themselves without an implement attached.
How do you attach your implement if the arms wont lower alone?
/ L3130 3 Point hitch won't lower unless weighted #9
This does not sound normal to me. I drop 3pt's with no implements on the back every week and I've never experienced this.
/ L3130 3 Point hitch won't lower unless weighted #10
It is quite normal for a new tractor. As you break it in and things start getting worn, then they have a higher chance of going down by their self. I have seen tractors with several hundred hours where they still needed to be pushed down but that doesn't happen very often.
/ L3130 3 Point hitch won't lower unless weighted #11
U-B said:
Well, the service manager at my local Kubota dealership says that this is normal! :
Hmmm let me think, let me think.....Cough cough {Bull Snit!!} cough
I'd get a second opinion at a dealer with a clue.
jb
/ L3130 3 Point hitch won't lower unless weighted #12
I call bull-snit, also. The dealer might have mentioned the rate-of-drop valve, but to say that this is normal...is not normal.
/ L3130 3 Point hitch won't lower unless weighted #13
Mine doesnt do that and never did. So is it normal to stick or is it normal not sticking?
I suggest you take it back to the dealer and tell him to work on it...
/ L3130 3 Point hitch won't lower unless weighted #14
The 3PH should lower with nothing on it. Mine always has. Not to say a new one couldn't be mechanically tight at some point as was noted. I just wouldn't think that the norm.
/ L3130 3 Point hitch won't lower unless weighted #15
It's not normal. If it was the MMM would never go down (there's no way to add weight to it).
/ L3130 3 Point hitch won't lower unless weighted #16
Mine lowers with no weight on it. Take it back to the dealer. It is not designed to operate that way.
/ L3130 3 Point hitch won't lower unless weighted #17
I only have 20 hrs. on mine no problems there.I did have a problem with getting the pto to disengage.
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
JOHN DEERE 8200 18 ROW GRAIN DRILL (A60430)
JOHN DEERE 8200 18...
(10) UNUSED 2.5" RATCHET STRAPS (A60430)
(10) UNUSED 2.5"...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
