L3010HST
/ L3010HST #1
steveky
Philpot, Ky
Kubota/ L3010HST, BX 1800
I'm looking for a finishing mower, the dealer I bought my tractor from a couple of weeks ago is trying to push a 7' Farmking he has in stock instead of ordering a 6'. Has anyone used a 7' behind one of these tractors, I have hilly ground and I don't want to bogg down my machine. Thanks in advance for your response.
Steve
/ L3010HST #2
Steve -- Probably depends on your definition of hilly. I use a LandPride 2572 rear discharge finisher with my L3010HST. It does a fine job in the meadow, even after a heavy dew, but going up my 22% slope I have to slow to a crawl.
Remember: that's a LOT of weight way out on the back of the tractor. Going uphill in transport mode I don't even raise the 3PH.
Pete
/ L3010HST #3
I have a RD72 (6') RFM i pull behind my 3010HST. I have had problems on some of our hills (minor bogging). In med. it makes it up them okay but I wouldn't want any bigger for sure. Oh yea, i did have the FEL loader on when doing this, and i have R4 tires.
/ L3010HST
Thanks, if the dealer will let me try the 7 footer before I buy I might go for it...just don't want to slow things down.
/ L3010HST #5
STEVE: the 7 ft may be fine in dry , low grass conditions. but i think i would opt for the 6 ft. but if he lets u try it out , u may find different.i personally prefer to go with the smaller unit, it is easier on the tractor and only a few times more around the cutting area, plus factor in your peice of mind.
/ L3010HST
Your right Frank, I think it would handle it fine on flat ground, don't want to have to worry about picking it up on a hill. You never know what conditions or situations you can find yourself in.
Thanks
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
1137 (A63291)
1137 (A63291)
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
1989 Corvette Convertible (A61574)
1989 Corvette...
