L3010 won" start
/ L3010 won" start #1
Larrythetarheel
Henderson
Kubota
My Kubota L3010 which has been great up until now, just begin to have a starting problem. The battery is good testing at 12.6 volts. When I turn the switch I would get one click then dash light would go out. Now turn the key and get no dash lights and no click from the starter.
/ L3010 won" start #2
Try jump starting it , even though the battery tests 12.6 amps it may still be bad or need charging . It is worth a try before going other routes .
/ L3010 won" start #4
How are you making out ? I was hoping someone with more knowledge than myself would have chimed in by now. It could be a solonoid , dead spot on starter . I have seen people tap the starter to try and get it to work , not sure how good that works .
/ L3010 won" start #5
I'm assuming that you cleaned the cables when you took out the battery to test it but make sure they are clean and tight on the other end as well. A bad ground could cause this.
Sent from my iPad using TractorByNet
80003CFL (A61568)
80003CFL (A61568)
2020 Deere 544L (A60462)
2020 Deere 544L...
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
Case CX75C (A62177)
Case CX75C (A62177)
