L2900
/ L2900 #1
sonny
Lillian,Texas 76061
M9000-L2900(kubotas)
My L2900 only has 400 hrs,and I think a bearilng in the rear axle maybe out.
It makes a popping noise like the wheel is loose.Any suggestions would be appricated.
thanks
/ L2900 #2
If the wheel in question has a center disc bolted to the axle flange with the outer rim bolted to the disc, check the outer bolts. If they work loose at all, it will make a popping sound as it shifts around, and sound a lot like a dry bearing. It's far more likely than an axle bearing failure with only 400 hrs
/ L2900
thanks for the reply,i will try that
i posted again,didnt know where the listing was?
thanks
/ L2900 #4
I have the same problem by my L2900 gst has 846 hours. I will check the wheel lug nuts first thing tomorrow. I noticed it while picking up my hay....I place it in 2nd and let it go while I load the bails on the trailer. I placed my hand on the wheel as and it popped at a specific spot.
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
Rigid Pipe Threader & Pipe Stand (A62613)
Rigid Pipe...
