L2800 will not start
/ L2800 will not start #1
jveretto
Buffalo, TX
Kabota L2800
I have had an L2800 for 4-5 years. Never a minute trouble. Today, I started tractor and went to front yard where daughter has thrown a toy into the tree. I parked under the tree ,shut off, and took a stick and dislodged the toy. I had to fold the seat up and stand on the seat base. I know, bad move! Got ready to move tractor and it would not start. Not a click, not a grunt, not nothing. Checked battery, fully charged. I suspect the seat switch because that is near where I was standing even though I was careful not to step on it. I have tried every position with switch in case it was out of adjustment. I've taken the switch off. It does not come apart. Thought I would wire around the switch but said switch has three wires, red, blue, & black. Any suggestions to trouble shoot the switch. Thanks in advance for your help! Really don't need any criticism about standing on the tractor! I know!
/ L2800 will not start #2
HST or gear? check the other safety crap... HST rocker in the middle? just jump seat switch...
The HST rocker is in middle. How do I jump the switch with 3 wires? Thanks!
/ L2800 will not start #4
Wire tie it down... do you think the switch itself might have been damaged?
With no click, I'm still thinking safety switch... PTO off?
Yes sir, I agree. I think the switch is malfunctioning. The arm that is activated by the seat bracket makes no sound or click as I would expect when I move it. Switch bolts to the seat bracket so it mechanically moves the switch arm. Yes the PTO is off. Thanks again!
/ L2800 will not start #6
I don't know how the seat pressure switch works on your tractor, but you can generally bypass them with a simple jumper wire to complete the circuit.
Yep but it has three wire. Which do I jump? That was in my first post. I don't know how to jump a three wire switch. Thanks!
/ L2800 will not start #8
I don't think it makes a click... will check it in the morning.
/ L2800 will not start #9
Mine does not make a click my old ears can hear.
While I have an HST my service manual is for a gear.
According to the schematic the 2 position seat switch senses seat down for starting and seat tilted up for PTO operation.
You would jumper red/white to red/black for starting.
The red/white is switch common. red/black is for starting and blue/yellow is for PTO.
Before you jump the switch you might try rapping it with a screw driver handle in case it is just stuck.
Trail King Trailers Parts Books Vol. 1 and Vol. 2 (A63117)
Trail King...
(INOP) TAKEUCHI TL10V2 SKID STEER (A64280)
(INOP) TAKEUCHI...
159116 (A60430)
159116 (A60430)
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
2013 Honda Pilot AWD SUV (A61574)
2013 Honda Pilot...
