L2800 HST PTO shift lever problem
/ L2800 HST PTO shift lever problem #1
philipb
East Texas
Kubota L2800 HST Cub Cadet GT2544
All of a sudden, the shift lever won't disengage the pto. In either position, it just keeps on running. Any ideas before I take it off and lose a few parts?
/ L2800 HST PTO shift lever problem #2
The cable get corroded and won't let it engage.
/ L2800 HST PTO shift lever problem #3
Same thing happened to my a couple of yrs ago. Research pointed to clip on end of cable inside main housing. Estimated repair $2500.
/ L2800 HST PTO shift lever problem #5
My L2800 is about two years old and had this problem. There was a factory recall on the cable and my dealer replaced it free. Check with your dealer and if he does not know of it shoot me a PM and I will give you the name of my dealer and service manager.
/ L2800 HST PTO shift lever problem #6
I had mine replaced twice under warranty, the last time it included a new bracket that was supposed to help this, but the other day it was sticking again. My tractor is no longer in warranty so I took a syringe and needle and injected a little engine oil in into the top rubber boot now it works fine again. The sticking cable can end up tearing up your gears inside the transmission if it only partialy engages. It is a poor design but I looked at some new Grand Ls and they had a cable setup too.
/ L2800 HST PTO shift lever problem #7
Most of you guys are lucky. Mine still sticks after I got the bracket and cable replaced, because it's not the bracket or the cable.
The lever on the transmission housing is stiff and I just don't see an easy way to deal with it, so I find my self under the tractor shutting it off by hand and every time I need it to stop. Problem is, I'm a bit safety conscious so I usually have to shut the machine down too. It's a real nuisance.
Good luck philipb, hope you just need a little lubrication.
/ L2800 HST PTO shift lever problem #8
I wonder if it had a stiffer spring on it if that would help.
/ L2800 HST PTO shift lever problem #9
So would it be possible to just add a lever and do away with the cable?
/ L2800 HST PTO shift lever problem #10
Great thought, that just might help with the sticking cable too!
Might take some research, not sure how/where to get one that would be a perfect fit, mine needs another 4 lbs of pressure based on my sense of applied force and a small scale. 5 lbs. would be a sure bet. Seems reasonable.
Anyone know a spring resource?
/ L2800 HST PTO shift lever problem #11
I'm pretty sure it's possible, I think it's the same lever on our transmission housing that you'll find on the gear model but ours is actuated by cable because the HST pedal is in the way. There doesn't appear to be an aesthetically convenient or practical place to put one though.
All of these ideas have helped, they made me think. I went back to the lever, the cable, and then the boot that surrounds the cable (the boot is less than an inch long). It turns out that the cable sees so much resistance down in its jacket that it just kind of bends in the area that the boot covers. I held the boot between two fingers and moved the lever, the cable straightened out, actuating the cable through the cable jacket, and, evidently, disengaged the pto. Some oil through a siringe is probably needed.
Now, what a pain in the butt. This is bad engineering. It is unsafe. I'll check with Kubota in Ft. Worth about a recall because of the safety issue. I wonder what their solution is. I like the way this machine works but this is one of a few problems that just make no sense to me about it.
Thanks to all for your help. Phil
The more that I think about this, the more I think that Kubota has cheapened out on the selection of their cable. A more rigid cable would really help, and, locking down the end that is attached to selector would help in the lever putting a lot more concentrated force on the cable inside the jacket. One of my customers builds custom control cables. I can see a design that is all metal and much more rigid, like a wrapped wire jacket, and a heavier wine inside of it. The cable on there now just kind of flops around.
/ L2800 HST PTO shift lever problem #14
I've used Honda cable lube (motorcycle product) on mine. I have not yet had trouble at 230 hours. If it sticks I will manufacture a hard lever to operate it. I'm sure it is possible but may take some doing.
One should disengage the PTO at the sme time as pushing in the clutch. Once the mechanism stops rotating it will take more force to disengage.
/ L2800 HST PTO shift lever problem #15
I agree about what is happening, I looked at both of my failed cable and where it bends the strand flare out and makes it so the cable do not slide correctly, a better quality (stiffer) cable would probably work. I have been thinking about a solid lever but have not come up with a working idea.
/ L2800 HST PTO shift lever problem #16
The leaver on my transmission housing definitely sticks but this is good advice and will probably help. I usually tolerate that horrible ratcheting sound till the end, despite a lot of TBN advice against it, because my manual says to.
My problem is, when the lever sticks I'm often not getting a full disengagement and I fear just catching the lips on the cams with a partial disengagement or delayed release and rounding them off, causing failures like 8226hamer had.
/ L2800 HST PTO shift lever problem #17
I disengage exactly the way ccsial does - disengage the same time as I push the clutch.
I can't see why there would be any problem with this. I lube the cable with silicone lubricant but do have a problem getting it right in the hole.
ccsial - does the honda cable lube come with something special that ensures the lube goes down to the cable.
Kubota has been using cables for PTO disengagement for along time as far as I can tell. A friend of mine has a B7200 whose hour meter broke at 2k+ hours about 5 years ago and it seems to have a cable mechanism as well. He's had zero problems.
So far I am crossing my fingers as I have had next to no problems with my machine at 190 hrs and 3+ years.
/ L2800 HST PTO shift lever problem #18
Idoes the honda cable lube come with something special that ensures the lube goes down to the cable.
Nothing spedial. It has the plastic tube that most spray lubes come with. I lube from the top in hopes that it runs down hill.
/ L2800 HST PTO shift lever problem #19
This is one time I disagree with the manual. When you press the clutch the ratcheting begins. Disengaging the PTO during this time is easy since it is unloaded.
There is a small rake angle on the old style clutches. Once it stops the cable has to overcome this extra friction to disengage.
Besides that, disengaging at the same time as the clutch is pressed reduces the ratcheting which should be less wear.
If I recall correctly 8226hamer had the failure from rototilling. I would not operate a tiller with mine unless I had the new style PTO clutch installed. My suspicion is that the tiller causes chatter on the clutch which tends to destroy it. That痴 just my theory, no proof.
/ L2800 HST PTO shift lever problem #20
Yeah, I'm on board with the disengage at clutch method now, too many good reasons to ignore the manual on this one. Still not sure why the leaver sticks, maybe I just need to wear it out a little.
I don't discount the tiller theory but mine was always that 8226hamer's problems may have been a result of poor or partial engagement as a result of this prolific cable complication.
It's a tough guess because I can't recall another PTO failure since, lots of people use tillers, lots of people have sticking cables. Maybe he just got a lemon.
