L2800 HST, engine cranks but no start
   / L2800 HST, engine cranks but no start #1
Boatman62
Mill Spring, NC
Farmall H, JD 4110, Kubota L2800, Kubota BX1870
I used it today for some light grading work. Parked it to talk to someone and 30 minutes later it wouldn't start. Turn the key and the engine cranks but won't start. The thing I noticed right away that is different is there used to be a fairly loud clack when turning the key on. The clack is gone. I assume there is a fuel relay someplace. I checked all the small fuses on the left side and the three main fuses up by the battery. Also made sure the clutch was depressed, the PTO lever was disengaged and rocked the pedal back and forth.
Any ideas where to start looking?
Is there a wiring diagram somewhere? I looked on the Kubota website but I must be missing it if it's there.
Couple other things to note... The seat switch has been tie wrapped down since I've owned the tractor. And the fuel gauge stopped working a couple months ago, just reads full all the time.
   / L2800 HST, engine cranks but no start #2
Do you have operator's manual,if so check out troubleshooting section in the back.
1.Air or water in fuel line.
2.Weak battery or bad connections.
3.Low fuel or fuel filter.
Yes, I have checked all the preliminary items and have looked at the useless "Troubleshooting" chart in the manual.
Like I said,, the loud clack when turning on the key is no longer present. I believe the clack was the fuel solenoid being energized.
   / L2800 HST, engine cranks but no start #4
Sounds like your fuel shutoff solenoid!
So I went down after my last post and turned the key,,,, no clack again. Left the key in the on position (with the clutch pedal locked down) and moved the manual fuel cutoff lever back and forth. As soon as I moved it the solenoid engaged. Turned the key and it started immediately. The solenoid clack seems not to be as robust as before so I'm thinking it may be on the way out or a bad connection. I'll pull it in the shop later and check the connector for corrosion.
   / L2800 HST, engine cranks but no start #6
Some of the Kubota fuel solenoids, have 2 windings, one for pullin and one for hold.
David
   / L2800 HST, engine cranks but no start #7
Thanks for the update Boatman62... just might come in handy down the road for me.
   / L2800 HST, engine cranks but no start #8
What's a HST doing with a clutch pedal?
   / L2800 HST, engine cranks but no start #9
Kubota has clutch bell housings on the L and Grand L series as there are 3 transmission choices and different PTOs and would guess they would not want to re engineer everything just because of the hydro.
David
   / L2800 HST, engine cranks but no start #10
Not sure but I've got one. The only purpose mine has is to disengage the trans when I shift into the different ranges. Kubota insists that be done when shifting. Also, I need to step on the clutch as a safety-start feature before I can start tractor. It all seems normal and natural to me. Oh, to engage either PTO I also have to step on the clutch.
2013 Haulotte 4527A (A50120)
2013 Haulotte...
2014 Dodge 5500 4X4 Bucket Truck (A52748)
2014 Dodge 5500...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2003 Komatsu WA250 Articulated Wheel Loader (A50322)
2003 Komatsu WA250...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
