L2800 HST, engine cranks but no start
   / L2800 HST, engine cranks but no start
So I figured I'd give an update on this issue. Still having the issue and it progressed to the point of tapping the solenoid didn't work anymore. But I did notice that wiggling the electrical connector energized the solenoid and it would start. I pulled the solenoid and bench tested it and found nothing wrong. Reinstalled and made a couple jumper wires to go from the electrical plug to the solenoid and it worked perfectly for over a week. Pulled the jumper and plugged in the connector ,,, no worky. So it's the connector. I pulled the individual connectors out of the plastic housing and bent them to provide better contact and now it works perfectly again. Going to have to source a new connector.
Glad I figured this out as I was ready to drop the bucks on a new solenoid that wouldn't have fixed the problem.
   / L2800 HST, engine cranks but no start #12
Good thinking.
Diagnostics in the key to a happy tractor life.
   / L2800 HST, engine cranks but no start #13
Thanks for the update. :thumbsup:
   / L2800 HST, engine cranks but no start #14
Ditto, thanks for updating!!! :thumbsup:
Man Basket for Forks on Casters (A57454)
Man Basket for...
3 Point Hitch Hay Spear (A57454)
3 Point Hitch Hay...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
