L2650 - Brake rod - is it bent?
   / L2650 - Brake rod - is it bent? #1
SouthernSky
Deville, LA
2013 Kubota L3200DT
I looked under my tractor yesterday for possible damage and noticed the adjustable brake rod/link was perfectly straight except the ends were slightly dog-legged. It sort of looks like: \______|_/ instead of like ________|_ though the up-angle is not as steep as my drawing, maybe 5 degrees. (The vertical line is the adjustment nut).
I cannot see any signs of scraping that would indicate damage. So is this damaged or is this a factory offset?
   / L2650 - Brake rod - is it bent? #3
Rod and ends should be straight - see owner's manual page below. That said, a little bend may not hurt anything - may make the brake pedal mushier than normal.
  • L2650 brake adjust.pdf
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
2017 Ford Explorer SUV (A50324)
2017 Ford Explorer...
1973 TANDEM AXLE DUMP TRUCK (A52576)
1973 TANDEM AXLE...
20711 (A50323)
20711 (A50323)
Polaris Side by Side (A50324)
Polaris Side by...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
