L2650 - Brake rod - is it bent?
   / L2650 - Brake rod - is it bent? #1
SouthernSky
Deville, LA
2013 Kubota L3200DT
I looked under my tractor yesterday for possible damage and noticed the adjustable brake rod/link was perfectly straight except the ends were slightly dog-legged. It sort of looks like: \______|_/ instead of like ________|_ though the up-angle is not as steep as my drawing, maybe 5 degrees. (The vertical line is the adjustment nut).
I cannot see any signs of scraping that would indicate damage. So is this damaged or is this a factory offset?
   / L2650 - Brake rod - is it bent? #3
Rod and ends should be straight - see owner's manual page below. That said, a little bend may not hurt anything - may make the brake pedal mushier than normal.
  • L2650 brake adjust.pdf
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
John Deere 310K Backhoe (A51573)
John Deere 310K...
