L260 stops running
/ L260 stops running #1
EMK
My kubota L260 starts fine but after 1-2 minutes the engine will die - it acts as though it is not getting any fuel. Fuel Filter perhaps? can anyone offer any help?
/ L260 stops running #2
Fuel filter is a good starting point and if you have a fuel shutoff valve in the system somewhere should also be checked.
Check for fuel contamination, water or if it may have been filled with something not intended for a diesel engine.
Air filter should be checked also.
/ L260 stops running #3
Perhaps try bleeding the system. If you changed fuel filters you have to bleed the air. Atleast I do on my L175.
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
Werk Weld (WW) Portable Creep Feeder (A66408)
Werk Weld (WW)...
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
Fertilizer Openers (A65640)
Fertilizer Openers...
John Deere 185 Hydro Riding Tractor Mower (A66285)
John Deere 185...
