L2500 Greasing Question
/ L2500 Greasing Question #1
MikeGross
Illinois
Kubota L2500DT
I am in the process of performing the 50 hour service on my L2500. The service manual indicates that there is a grease fitting inside the clutch housing, but I don't see any obvious place to grease.
Any guidance would be greatly appreciated! Thanks.
/ L2500 Greasing Question #2
Mike:
The fitting that you refer to is under a plate below the steering wheel and if I remember correctly I read someplace that you do not have to grease this fitting untill you have that plate off for some reason related to the clutch which may be never. I found the picture on page 46 of the maintenance manual. I can't seem to find where I read about not greasing that though. I'll keep looking and if I come up with the official word I'll let you know. I have never greased the fitting on my L2500 and I try to do all the maintenance requiredl.
P.K. Burke
/ L2500 Greasing Question #3
Mike:
Back again. After further perusal of the operators manual, I found the info on page 41 under the lubricants list. Go to the bottom of the list and you should see "clutch release hub" grease when disassembled. I knew I saw that somewhere. Have fun with your L2500.
P.K. Burke
Thanks for the information. I think I will just leave the clutch alone unless I have a problem with it...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
CASE INTERNATIONAL 39 DISC HARROW (A64278)
CASE INTERNATIONAL...
TAYLOR 2R MULTI-PASS HARVESTER (A64278)
TAYLOR 2R...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
Sunflower (A64557)
Sunflower (A64557)
46177SFL (A64557)
46177SFL (A64557)
