L series remote valves
/ L series remote valves #1
RichNJKubota
Hunterdon County, NJ
Kubota L4310HST
I need to get one remote valve kit for my L4310HST Kubota. I know this is expensive. Does anyone have any recomendations for the cheapest dealer?
I'll also be buying some other less expensive parts also.
Thanks,
Rich
NJ
/ L series remote valves #2
Try priceing the gearmore kit, 2 or 3 spool it should be cheaper, and its better to use, at least with a grader box. it mounts off of the ROPS, makes a good handrest
/ L series remote valves #3
You can probably find it darn cheap if you shop around and have someone UPS it to you. Only caveot is that they are not easy to install.
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
(1) 30 Yard Roll Off Dumpster and (1) 20 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
New 4ft Bushog Rotary Cutter (A65579)
New 4ft Bushog...
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
2023 Blue Diamond 103030 Extreme Duty Cutter (A65640)
2023 Blue Diamond...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
