3-Point Hitch L-series Jerky 3PH - Jeff's homebrew repair.
   / L-series Jerky 3PH - Jeff's homebrew repair. #161
I take it that there are no B's that are large enough? How about a GL? If not the only option left would be to cancel the deal.
If it were me, I wouldn't even consider keeping the 3200 if the hitch was jerky. As I have stated before, the only fix I know of is to stay away from the standard Kubotas and buy a Grand, or change brands.
Does your dealer sell anything else?
Bill
He is going to run smack into the wall of the Grand L's are so much more money. The B 3350 is close, just a bit lighter, but the 3pt is quarter inching, NO position control.
   / L-series Jerky 3PH - Jeff's homebrew repair. #162
When I found myself in a similar position, I ended up going to a L3240GST that had been on the lot for a year. I did need to fork over an additional $1800.
   / L-series Jerky 3PH - Jeff's homebrew repair. #163
Still waiting to hear from the dealer. He's checking what he can substitute for me. I'll check out the B3350, but if it's lighter I don't want it. What's quarter inching. no position control? How much more will the grand L be at a good price from him?
   / L-series Jerky 3PH - Jeff's homebrew repair. #164
How does the L3240GST compare to the L3200?
   / L-series Jerky 3PH - Jeff's homebrew repair. #165
If he could find a 3240 or 3540 left over (unlikely now) that would be a great deal.
   / L-series Jerky 3PH - Jeff's homebrew repair. #166
A much more refined machine. Will have a smooth hitch, and many more features like telescoping lower links and stabilizers. You have to decide if the GST is the transmission for you. It is a very refined and deluxe hydraulically controlled standard transmission.
   / L-series Jerky 3PH - Jeff's homebrew repair. #167
The L3240 will also weigh quite a bit more than the L3200
   / L-series Jerky 3PH - Jeff's homebrew repair. #168
You can compare costs on the build it yourself site.
In my case the L3240GST was on the lot. Had it been a gear transmission instead of a glide shift the cost difference would have been more like $800.
A L3240 is a lot more tractor than a L3200. The frame size is close to, or the same as a L4400. It's a nice tractor.
I found mine a little underpowered, but I'm located at 3000ft. You loose more HP than you think at that elevation.
Bill
   / L-series Jerky 3PH - Jeff's homebrew repair. #169
I'll ask about the L3240. That sounds way better than the L3200. thanks. Still waiting for the call.!
   / L-series Jerky 3PH - Jeff's homebrew repair. #170
Well after using the l3800 a little I'm not even noticing any jerky . So I guess I got a good one .
Sent from my iPhone 5 using TractorByNet
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
Trailer (A55973)
Trailer (A55973)
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
John Deere 5055E (A53317)
John Deere 5055E...
