3-Point Hitch L-series Jerky 3PH - Jeff's homebrew repair.
   / L-series Jerky 3PH - Jeff's homebrew repair. #161
I take it that there are no B's that are large enough? How about a GL? If not the only option left would be to cancel the deal.
If it were me, I wouldn't even consider keeping the 3200 if the hitch was jerky. As I have stated before, the only fix I know of is to stay away from the standard Kubotas and buy a Grand, or change brands.
Does your dealer sell anything else?
Bill
He is going to run smack into the wall of the Grand L's are so much more money. The B 3350 is close, just a bit lighter, but the 3pt is quarter inching, NO position control.
   / L-series Jerky 3PH - Jeff's homebrew repair. #162
When I found myself in a similar position, I ended up going to a L3240GST that had been on the lot for a year. I did need to fork over an additional $1800.
   / L-series Jerky 3PH - Jeff's homebrew repair. #163
Still waiting to hear from the dealer. He's checking what he can substitute for me. I'll check out the B3350, but if it's lighter I don't want it. What's quarter inching. no position control? How much more will the grand L be at a good price from him?
   / L-series Jerky 3PH - Jeff's homebrew repair. #164
How does the L3240GST compare to the L3200?
   / L-series Jerky 3PH - Jeff's homebrew repair. #165
If he could find a 3240 or 3540 left over (unlikely now) that would be a great deal.
   / L-series Jerky 3PH - Jeff's homebrew repair. #166
A much more refined machine. Will have a smooth hitch, and many more features like telescoping lower links and stabilizers. You have to decide if the GST is the transmission for you. It is a very refined and deluxe hydraulically controlled standard transmission.
   / L-series Jerky 3PH - Jeff's homebrew repair. #167
The L3240 will also weigh quite a bit more than the L3200
   / L-series Jerky 3PH - Jeff's homebrew repair. #168
You can compare costs on the build it yourself site.
In my case the L3240GST was on the lot. Had it been a gear transmission instead of a glide shift the cost difference would have been more like $800.
A L3240 is a lot more tractor than a L3200. The frame size is close to, or the same as a L4400. It's a nice tractor.
I found mine a little underpowered, but I'm located at 3000ft. You loose more HP than you think at that elevation.
Bill
   / L-series Jerky 3PH - Jeff's homebrew repair. #169
I'll ask about the L3240. That sounds way better than the L3200. thanks. Still waiting for the call.!
   / L-series Jerky 3PH - Jeff's homebrew repair. #170
Well after using the l3800 a little I'm not even noticing any jerky . So I guess I got a good one .
Sent from my iPhone 5 using TractorByNet
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
Utility Trailer (A52377)
Utility Trailer...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
UNUSED 48 in. Heavy-Duty Bolt Cutters (A53117)
UNUSED 48 in...
2019 Ford Fiesta SE Hatchback (A55853)
2019 Ford Fiesta...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
