3-Point Hitch L-series Jerky 3PH - Jeff's homebrew repair.
   / L-series Jerky 3PH - Jeff's homebrew repair. #141
To answer Texas Boy's question, I did adjust mine to the specs in the workshop manual, which were quite different to the factory settings in one dimension. It was butter smooth when I was done.
The problem that caused was that the implement was being "held" dynamically by flow through the 3pt position control valve mounted above the transmission, inside the tranny case.
When you used the loader valve or the remote hydraulics, whatever implement was on the lift arms would drop a couple inches, then snap back up as soon as you stopped using the other hydraulics.
It is a series circuit, using "power beyond", or "high pressure carry over" as it's known in Europe. Unless downstream valves, such as the 3pt control valve in this case (last valve before the sump), are closed, any use of upstream hydraulics, such as the loader or remotes will affect the 3 point arms' position.
It was bad enough I decided it was worse than the original jerkiness and I reset the valve to it's original condition. LD1 found the same thing with his, as did SMWeatherman on his MX4700.
So, I think they were deliberately set incorrectly to minimize a problem the factory techs at Kubota know there's no easy fix for.
In short, if it walks like a duck, sounds like duck, looks like a duck.. It's a duck. No way all three tractors were set "wrong", three different years and 2 different models. And coincidentally set "wrong" to an adjustment that eliminates pogo-ing of the 3-point at the expense of smooth operation? Come on, really? What it is, is a compromise, and nothing but.
If you want to read the thread on my adjustment saga, it's here, just search for L3400 3-point hitch adjustment, there are pics too.
The reason SMWeatherman's and Jeff's works better is that the pc flow control valve has a damping effect on the flow of oil to the cylinder.
Just for fun, try standing on the lift arms and slowly raise the lift at idle. It'll feel like someone's hitting the soles of your boots with a hammer.
Like James said, other than this issue it's a great tractor, they just didn't correct the 3-point operation in the design phase.
If you'll excuse me, I need to check my blood pressure... ;)
Sean
   / L-series Jerky 3PH - Jeff's homebrew repair. #142
I am like others on here. I just learned to live with it after reading all the posts about this problem. If I did a lot of work that required a smooth 3 point I would probably have a different attitude.
Now the dealer saying there were no issues with the 3 point and then handing it off to you is another matter. He is either lying or this is the first one he ever sold. Or possibly he is just a nice guy that is mentally challenged.
That said. Other than the 3 point issue, my L3200 has been a great tractor.
I hope you get things solved to your satisfaction.
   / L-series Jerky 3PH - Jeff's homebrew repair. #143
I think it is funny he said that this isnt a common problem.
Just like other KUBOTA dealers that are members/sponsors of this very website (who will remain nameless), Claim they have NEVER seen NOR sold one of these with a jerky hitch:mur: And like Kubota "corporate", deny a problem even exists.:confused2:
   / L-series Jerky 3PH - Jeff's homebrew repair. #144
I just find it unbelievable that after spending the $$ that these tractors cost, the Kubota corp. and the dealer say tough luck, and there is no recourse.
   / L-series Jerky 3PH - Jeff's homebrew repair. #145
My dealer was good about it, did their best to get some help from Kubota but ran into the "this is the way they're supposed to work" stone wall. I'm satisfied with their efforts and would buy another tractor from them. I've learned to live with it, other than a few particular jobs it's no problem, although it does make hooking an implement a bit difficult at times.
Sean
   / L-series Jerky 3PH - Jeff's homebrew repair. #146
Sean
Yep, I was very satisfied that the second dealership I went to (not the one I bought it from) did everything he could to try to solve it, by working with the regional rep and myself. But he got the same message from this rep, and that was that. My Regions rep was not willing to do anything to help my plight. And why should they, this line of tractors is one of the best selling tractors on the planet.
   / L-series Jerky 3PH - Jeff's homebrew repair. #147
I thought you said your dealer is picking up the tractor on his dime? Give him a chance man...:cool:
   / L-series Jerky 3PH - Jeff's homebrew repair. #148
Whatever you do, please come back here and tell us what happened, what was said, and if it was fixed, HOW was it fixed. Pin them down. Mark the top of the valve assembly in some inconspicuous way. (under the seat) so if they change out the valve assembly, you will know. We are counting on you.:thumbsup:
   / L-series Jerky 3PH - Jeff's homebrew repair. #149
Where's that ?
   / L-series Jerky 3PH - Jeff's homebrew repair. #150
He said that this isn't a common problem and he will run a pressure test on it to see what's wrong.
Red flag #1 -- either he doesn't know what he's talking about, or he's not being truthful.
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
24in pin on excavator tooth bucket (A56435)
24in pin on...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
More info coming soon! (A55787)
More info coming...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
