L series front seals
   / L series front seals #11
1200 miles?
Yeah, see I drive one mile per hour, so...:eek:
Actually 1200 hours; senior moment for lack of a better excuse; will change it; thanks for catching it.
   / L series front seals #12
............. does 600 hours seem low to have this problem?.........
Some leak sooner, some later, but most leak eventually.
The earlier models with bearings at the top of the kingpin didn't leak. But they were more expensive to make and the financial hamsters put an end to doing things that way.
Old ways are best - not because they're old, but because they're tried and true.
L5450
L345
   / L series front seals #13
Make sure that you have ballast on the rear of the tractor. A good rule of thumb in water in the rear tires plus the same amount a weight on the 3 point as you have in the bucket. Without the proper ballast, when doing loader work, the load shifts the tractor weight to the front axle. This puts way too much stress on the hubs and causes leaks (and other damage).
   / L series front seals #14
Think about your dealer's comment that they start to seep due to loader work. What about using a loader would cause seals to leak? It shouldn't be packing mud against the seal that would cause wear. It would be putting higher load on the bearings that will reduce life, and load reduces life by an exponent, not squared, not cubed, but actually to the 10/3 power for a tapered roller bearing. So bucket load drasticly reduces bearing life but I assume the designers take that into consideration when they design tractors like ours that almost always have a FEL. I say that as I look out my window at my neighbor's tractor he was using to load bales when one of the front wheels fell off - bearing failure that went way beyond leaking seals (it is a 2 wheel drive tractor). We used one of our tractors to finish loading his bales and also lift and block his tractor until he gets parts. Would be wise to check to see if your problem is more than just weeping seals some time when you aren't in a rush rather than end up like our neighbor with a broken leg on his tractor just when he needs it most.
   / L series front seals #15
L5450
L345
For sure a much better design!!!! :thumbsup:
   / L series front seals #16
My L4200 leaked with 322hrs, tractor is used for snow removal with Kubota Plow. I replaced both seals,and the cause of the leaks were dirt in the seal area. Kubota used a wear ring that must be removed when replacing seals. I checked the bearings and there was no wear and preload indicators looked as new, I'm sure the cause of my leaks was dirt, I used to pressure wash that area, not anymore. Replacement seal is a new design, hasn't leaked yet and has been going for six years now, not even a drip.
Thanks Texas Fella, I have loaded rears and always have my box blade and weight on the back.
From some of the reading here I might have done them in this winter driving / getting stuck :cool::D in some really deep snow and crust?
I think I will move to gear oil as it is time to change it again anyway.
Thanks all..
   / L series front seals #18
If you do loader work without a rear counterweight, it takes its toll. I learned this the hard way with my 1st kubota (2000 B7500)
   / L series front seals #19
One thing I have wondered about...the front axles are sealed, (at least on my L3830). There is not a vent tube coming from the axle. It seems that could also contribute to a seal leaking. The axle warms up with use and the air inside expands...or contracts when it cools off. Couldn't that make the seals leak? On my truck, the axles are vented...
   / L series front seals #20
My L3010 has an axle vent tube. It runs up into the engine cowling. Reason I know: It is all rotted and needs replacing.
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
More info coming soon! (A55851)
More info coming...
1302 (A58374)
1302 (A58374)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
PALLET TOTE OF BOAT MOTOR PARTS (A58374)
PALLET TOTE OF...
