L 2600 Remote Hydraulics
/ L 2600 Remote Hydraulics #1
xtruckerbob
Louisiana
Kubota BX 25D, Kubota Bx 2670, Kubota RTV, 900, Kubota L-2600, Kubota G-3200, Kubota Z121S, John Deere L-160
Has anybody added a remote to a Hydraulics L 2600? I am gather up parts to build a 4x8x2 dump trailer. Just wondering what is involed?
/ L 2600 Remote Hydraulics #2
I'm not familiar with the hydraulic workings of a L2600 but I did add one set of remotes to the rear of my L3400 some time back. Of course I had to do mine the hard way but there are other simpler ways to do this. You didn't mention if your tractor has a loader on it or not. If so, the loader valve might have a power beyond port that would make adding a rear remote to your tractor much easier. Hopefully someone else here has done this to their L2600 and can offer you better advise. My 2 cents. http://www.tractorbynet.com/forums/hydraulics/279524-kubota-l-series-rear-remote.html
No it does not have a loader.
/ L 2600 Remote Hydraulics #4
Your hyd supply line goes from the pump to a fitting under the seat.
There may be an adapter that will let you insert a line for a remote valve.
If an adapter is not available, you could cut the line and add compression fittings and insert the remote valve.
That valve you insert must have a relief valve as it will now set the relief settings for the tractor.
There is another relief valve on the 3pt case assembly.
/ L 2600 Remote Hydraulics #5
See if you can still get this 32400-99810 option hyd block outlet.
Maybe I should think this though before I post this but just thinking. I have a dead ZTR (Bad Motor). I saved it so I could build a side mount mower for the pond banks. ......... Any way would the Hydraulic pump off the mower lift the bed of the trailer running it off the PTO? I already have a 24 inch cylinder, an extra PTO shaft and a gear box so I could speed up the pump if I need to. I think a loaded trailer 4x8x2 would weigh in excess of #5000.
/ L 2600 Remote Hydraulics #7
I am pretty sure the pump on a ZTR is a hydrostatic/VSP pump.
You don't normally see a VSP pump powering cyl.
A one or two spool valve with PB would be ideal.
/ L 2600 Remote Hydraulics #8
Show a picture of the pump you are talking about.
I have not taken it off yet, but it is on an Encore ZTR. I will try to get it off this week sometime.
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
2015 John Deere CX15 (A60462)
2015 John Deere...
