Kubota zero turn oops....
/ Kubota zero turn oops.... #1
kubmech
Platinum Member
So you own a few Kubota tractors, all of wich have the same reservoir for the hyd/trans fluid. When servicing you do the right thing and drain the lower points in the rear axles as well as the main drain plug, replace the filters, refill and your on your way with a properly serviced machine....So you buy a "ZD" to do some mowing, at 50 hours you do the service, you drain the low points in the rear axles, refill the trans and go, right? Maybe you just breezed through the manual and you miss the part about the rear axle housings being a seperate service item and understandably don't notice the dipstick plugs in the top of each housing (kind of hard to see).
In this case off you go with NO fluid in the rear axle housings.
It has happened enough times, just thought I'd throw out the info..............................................................
/ Kubota zero turn oops.... #3
Guess that is good information to know.
Now, if only I can remember that when and if I ever buy one, or possibly help someone that has one.
Kelvin
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2022 WEILER S450 SKIDDER (A65056)
2022 WEILER S450...
FOUR PALLETS OF MISC ITEMS (A67714)
FOUR PALLETS OF...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2017 PETERBILT 389 FITZGERALD GLIDER VOLUMETRIC MIXER (A67714)
2017 PETERBILT 389...
2016 Nissan Titan XD Crew Cab Pickup Truck (A66736)
2016 Nissan Titan...
