Kubota won't start
/ Kubota won't start #1
bota7800
Washington State
Kubota B7800
I posted this in the Kubota forum but only got 1 responder so forgive me for double posting.
I used the tractor about a week before - started right up and no problems. Then, last Friday it would not start. It cranks but does not start so it is not one of the safety systems.
I checked the fuses, they are fine. The air filter is clean - new this spring.
I checked the glow plugs, they have current and the one I pulled glowed when I put 12 V across it.
I pulled the fuel line into the pump, fuel flowed.
I took a line off at an injector and tried to crank. I did not see any evidence of fuel. Should I?
I took the fuel pump off and pumped the lever manually. It seemed to be pumping. (I could hear and feel it)
So I have air, current and fuel (apparently). It still seems like a fuel issue to me but I have no other ideas.
Thanks for any help
/ Kubota won't start #2
It could be the seat switch.
Have you tried putting a jumper wire in to see if it would start ?
Thanks JD4300.
I knew it would be something simple like that. I jumpered it and it started. I will get a couple new switches.
/ Kubota won't start #4
Thanks JD4300.
I thought that's what it was because it happened to me once... and that's how I became a member here... My tractor wouldn't start & my wife registered me here and "Kennyd" was the one that replied and said a seat switch. :D
Glad you found the problem!
Oh one more thing... If I was you I would keep a small wire with you on your tractor, because you never know when a switch will go bad.
Well, it looks like it isn't the safety switch afterall. :(
When I jumpered it last night it started. When I went to use it today it would not start again. I tested both switches, they have continuity.
I got it started again after many tries, shut it down and again had trouble starting it. Now I am thinking it might be the ignition switch as it seems to start when I have the key in one position but not when fully rotated. This may be a total red herring because I cannot explain how the starter is cranking in all cases.
I have since started it both with the seat switch jumpered and engaged.:confused:
Oh, and as for carrying a small wire; the tractor, bought used, came with the seat switch defeated. I still had the wire in the tool box. Good advice though.
/ Kubota won't start #6
I didn't think it would be the seat switch since the engine won't crank if this is unhappy. Got to be a fuel or solenoid issue - the starter switch could easily cause this!
Mike
The tractor is now starting fairly reliably again and there is evidence of fuel at a slightly loose injector tube.
I REALLY HATE IT when things spontaneously HEAL without a confirmed explanation. I figure it will quit again just when I most need it.
/ Kubota won't start #10
When it does want to start; check to see if you have power to fuel solenoid.
/ Kubota won't start #12
A bit north of you - Arlington/Marysville area
and i'm just east of monroe on hwy 2. nice to see PNW'ers here..
well i had a problem this weekend with mine, ended up having a clogged line between the fuel tank and filter bowl but it sounds like you've already got that covered. good luck!
Topsoil Trommel (A57453)
Topsoil Trommel...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
2012 Ford Expedition SUV (A61574)
2012 Ford...
2025 MB27 27in Mixing Bucket Skid Steer Attachment (A61572)
2025 MB27 27in...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
