Kubota won't start
/ Kubota won't start #1
bota7800
Washington State
Kubota B7800
I posted this in the Kubota forum but only got 1 responder so forgive me for double posting.
I used the tractor about a week before - started right up and no problems. Then, last Friday it would not start. It cranks but does not start so it is not one of the safety systems.
I checked the fuses, they are fine. The air filter is clean - new this spring.
I checked the glow plugs, they have current and the one I pulled glowed when I put 12 V across it.
I pulled the fuel line into the pump, fuel flowed.
I took a line off at an injector and tried to crank. I did not see any evidence of fuel. Should I?
I took the fuel pump off and pumped the lever manually. It seemed to be pumping. (I could hear and feel it)
So I have air, current and fuel (apparently). It still seems like a fuel issue to me but I have no other ideas.
Thanks for any help
/ Kubota won't start #2
It could be the seat switch.
Have you tried putting a jumper wire in to see if it would start ?
Thanks JD4300.
I knew it would be something simple like that. I jumpered it and it started. I will get a couple new switches.
/ Kubota won't start #4
Thanks JD4300.
I thought that's what it was because it happened to me once... and that's how I became a member here... My tractor wouldn't start & my wife registered me here and "Kennyd" was the one that replied and said a seat switch. :D
Glad you found the problem!
Oh one more thing... If I was you I would keep a small wire with you on your tractor, because you never know when a switch will go bad.
Well, it looks like it isn't the safety switch afterall. :(
When I jumpered it last night it started. When I went to use it today it would not start again. I tested both switches, they have continuity.
I got it started again after many tries, shut it down and again had trouble starting it. Now I am thinking it might be the ignition switch as it seems to start when I have the key in one position but not when fully rotated. This may be a total red herring because I cannot explain how the starter is cranking in all cases.
I have since started it both with the seat switch jumpered and engaged.:confused:
Oh, and as for carrying a small wire; the tractor, bought used, came with the seat switch defeated. I still had the wire in the tool box. Good advice though.
/ Kubota won't start #6
I didn't think it would be the seat switch since the engine won't crank if this is unhappy. Got to be a fuel or solenoid issue - the starter switch could easily cause this!
Mike
The tractor is now starting fairly reliably again and there is evidence of fuel at a slightly loose injector tube.
I REALLY HATE IT when things spontaneously HEAL without a confirmed explanation. I figure it will quit again just when I most need it.
/ Kubota won't start #10
When it does want to start; check to see if you have power to fuel solenoid.
/ Kubota won't start #12
A bit north of you - Arlington/Marysville area
and i'm just east of monroe on hwy 2. nice to see PNW'ers here..
well i had a problem this weekend with mine, ended up having a clogged line between the fuel tank and filter bowl but it sounds like you've already got that covered. good luck!
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
429858 (A61165)
429858 (A61165)
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
