Kubota will not move
/ Kubota will not move #1
GB007
Have a 23 HP diesel tractor; plate shows it is a L2500D. Tractor is not moving or very slowly if at all. Prior it would make a screaching sound as it ran. Engine is fine. Can see the threaded spline moving in hydraulic box until tractor stops then it does not move and squealling noise sometimes occurs. any suggestions??
/ Kubota will not move #2
GB007 said:
any suggestions??
It would help to to know which tractor you have.
The plate indicates L2500D
/ Kubota will not move #4
Brakes on? Brakes locked up?
Clutch burned out? Does squealing stop when you depress the clutch? When you let the clutch out, with the tractor in gear, what happens. You should hear it tax the engine a tad and then start moving.
I'm not sure what you mean byt the threaded spline, do you mean the pto shaft? Disengage pto and see what happens.
/ Kubota will not move #5
Sounds like you have clutch problems. The clutch disk could be down to metal and it is eating the flywheel and pressure plate up.
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
Club Car Carryall 6 Medical Utility Cart (A64553)
Club Car Carryall...
Demco Lowboy Trailer (A65563)
Demco Lowboy...
